Old 01-15-2004, 07:45 PM
GerG GerG is offline
Question Will my zz controller charge a dual?
I pretty much said it. Will my ZipZaps controller charge a dual celled car? I have
an adapter hooked up to it but I dont think it'll make a difference. Please show me how to do it if its needed.
I appriciate anyones help.
Old 01-15-2004, 09:42 PM
Sawblade's Avatar
Sawblade Sawblade is offline
Wheeeelie!
Nope, but a pair of C batteries will.
The controller will just show that it's charged as soon as you hook it up.
-=Sawblade=-
Wheelie poppin' Red ZZ F-150 - Rear soft microsizers tires, Front hard tires, beer keg tri-cell mod, anti-roll bars, wheelie bars, 1/8" body drop, rare earth steering magnet, dual return springs, steering stabilizer bar and spring suspension, 28K Orange ZZ motor, Red 12:1 gears, 22ga power wires, heatshrinked antenna wire, .
Old 01-16-2004, 08:52 AM
????But I just tryed charging it for a couple seconds and the light turns parcially red and when I took it off and it drove for a couple seconds with the adapter and not the Cs. What do you mean when you say "The controller will just show that it's charged as soon as you hook it up."?
Old 01-16-2004, 09:09 AM
Sawblade's Avatar
Wheeeelie!
That's what it did on mine anyways. The light would turn green almost immediately after I stuck the jeep on there. Now I just soldered two c batteries together and stuck the wires into the slots that the charger originially used.
-=Sawblade=-
Old 01-16-2004, 01:50 PM
I just swiched my ZZ multi-voltage adapter up to 4.5 instead of 3 and it works good!
Old 01-19-2004, 09:55 AM
hmm...i gotta try 6 volts see if its better.
dual cell controller nxnitrous22 Bit Char-G Mods and Projects 3 10-09-2003 01:32 AM
Charge Dual Batt With Your Controller hogjowlz Bit Science 19 06-23-2003 04:48 AM
FYI:Motor Works (clone) charging base will charge dual and triple battery setups. Clint Bit Char-G / MicroSizers 0 02-17-2003 04:09 PM
Can stock charger charge Dual cell?! nrmcj Bit Char-G / MicroSizers 13 01-13-2003 01:49 PM
A New Way To Charge Single And/or Dual Battery Bit Char-g!!~! BaY oN AiM Bit Char-G Mods and Projects 7 09-12-2002 06:19 PM
