01-09-2004, 08:11 PM
Topsoul to 540 out
Gear Probs...!!
Ok...i have searched the threads for a possible fix to my problem....no luck. So here it is:
I have this grinding noise and gear slipping when i run my car. If i try to drift there is a weird noise that sounds like clattering but much faster. I dont know what is causing this so please help
RCtunerzforum.tk
Your source for micro RC tuning!
Back Up My Hard Drive? How do I Put it in Reverse?
01-09-2004, 08:16 PM
I'm not a pyro, really.
every once in a while i have the same problem. i take the rear end out and clean everything. especially check if the driveshaft is in the spur gear correctly. take the screwdriver and clean the differential. if you have bearings or AWD make sure to clean all of that too.
NEVER UNDERESTIMATE THE POWER
Check the gears and see if there is anything wedged in them. See if they are properly installed, and try greasing them with a lubricant. I will see if I can find the correct one.
[Edit] this is it, http://www.radioshack.com/product.as...t%5Fid=64-2301
Chuckster...
01-09-2004, 08:34 PM
Topsoul to 540 out
Thx guys...ima try that stuff tonite. I cleaned my diff b4 when i had a loud screeching noise and cleaning it stopped the noise. Maybe if i clean it some more it might stop the prob.
RCtunerzforum.tk
01-09-2004, 08:44 PM
Glad to help!
01-09-2004, 10:43 PM
Topsoul to 540 out
AHH! no use...
well i cleaned everything that the gears connect to...lubed it with litho-sumthing grease...changed the motor. its still the same! there is still this grinding/skipping noise coming from the gears. Plz help if anyone knows the exact problem...
RCtunerzforum.tk
01-09-2004, 11:58 PM
Topsoul to 540 out
just in case nobody knows what im talking about...i attached a recording of the noise that my car makes when i rev it in my hand. Before i switched the motor, it didnt have that screeching noise, it had a weird grinding noise instead. When i run the car on the ground, the screeching disappears but then the grinding noise comes back..... Click here to listen (you may have to right-click and save target as)
RCtunerzforum.tk
01-10-2004, 03:05 PM
Topsoul to 540 out
I just found out the only the drift motor makes that screeching noise. The drag motor makes the grinding noise, the road race makes an even louder grinding (and is very very slow now...the gears slip) and the top speed barely even moves (but you can hear the gears slipping) I know its not the motor because i have checked. Its something with the gears or the diff
RCtunerzforum.tk
01-10-2004, 08:32 PM
Topsoul to 540 out
ok...Today i just figured out that the diff and the spurr gear dont get enough contact. Is there any way to fix this? anyone?
RCtunerzforum.tk
01-11-2004, 01:21 AM
Topsoul to 540 out
 Can someone please help?! i want to run my xmod...im bored
RCtunerzforum.tk
01-11-2004, 01:50 AM
MMM...You know those two screws that attach the back end to the middle chassis piece? Try taking those out and putting them in again, make sure that it goes in all the way and not crooked. I've had that problem before. Yours might be different.
01-11-2004, 01:55 AM
Topsoul to 540 out
Theyre not in crooked...they're straight. They go all the way in.
RCtunerzforum.tk
01-11-2004, 01:58 AM
Out of ideas... But maybe you could take a few pics of different angles?
01-11-2004, 03:23 PM
Topsoul to 540 out
Pics of...? the gears?
RCtunerzforum.tk
01-12-2004, 08:41 AM
yes the gears. did you check if the rear driveshaft holder was broke? try reseating that. you have to remove the motor, take the screws out and put them back in and put the motor back in. that might help. did you check the pinion? see if something is in it.
