Old 12-31-2003, 09:52 PM
Gaian's Avatar
Gaian Gaian is offline
I must be Nuckin' Futs!!!
Send a message via AIM to Gaian
Lightbulb Got bored today
(Kinda long)
And decided I wanted to do something to my xmod, but what?
Did I want to run 4-cells, 5-cells, 6-cells, did I want the lights???
Finally decided 'yes, I want them all' so I sat there and stared at everything for a while and made it fit.
For a few days, I was wondering what those 2 mounting spots in the roof were for, so I decided to use one of 'em to mount a battery holder.Then I went out and got me a light kit... found out what those 2 spots were for.
So, out comes the battery holder, in goes the light kit, lights are cool, gotta keep the lights. But I want more cells so out come the lights and sit there and stare at everything again.
I'd been hearing that both a 6-cell setup and the light kit will not fit, so I made 'em fit. Mounted the battery holder to one post, and the light kit right next to it.
Now, the wiring.
I still want the option of 4, 5, or 6-cell, so back to staring at the thing again. First, I clipped that pesky little black wire, then added a quick disconnect setup and there, it's still a 4-cell. Take the battery holder wires, and add another quick disconnect setup, and rehook the battery holder in line like it goes, and there, a 6-cell setup. But what about a 5-cell? Simple enough, just remove one of the batterys and add a jumper wire between the terminals, and it's a 5-cell setup.
And, everything fits nicely under the body, it's a skyline.
I like to have options, depending on what's going on that day...
Old 12-31-2003, 10:19 PM
RC 2NR RC 2NR is offline
TinyRC XModder
I might try that because I dont want to go out and buy another I-C3 charger and two batteries. Thanks.
Old 12-31-2003, 11:26 PM
KnotHole's Avatar
KnotHole KnotHole is offline
JesUSAves
Cool ...Getting Bored
You should get bored more often...sounds like a good idea...
Old 01-01-2004, 12:42 AM
Joey's Avatar
Joey Joey is offline
Only problem I can see with all that is weight. Without a definite plan of action, you pack on a whopping sixty grams or something, nothing to really worry about; but I know how some guys get about adding any kind of heft at all to their cars.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
Old 01-01-2004, 07:38 PM
I Shall Return!
so your car works properly with the 6 cells and light kit?
Old 01-01-2004, 09:35 PM
Gaian's Avatar
Thumbs up
No problems so far, still runs great. About the only 'problem' I had was during the setup. I had to Dremel a mounting hole in the battery holder, and it ended up being right in the center of one side of the holder, so the screw was in the way for the second cell. So, I just swapped out one of the flat headed screws from somewhere, and then the battery fit fine.
Old 01-02-2004, 10:41 PM
hoopsta1423 hoopsta1423 is offline
could u explain the 5cell part a lil better, i wanna try this with my rsx
Old 01-02-2004, 11:01 PM
Rx7NoZ's Avatar
Rx7NoZ Rx7NoZ is offline
your car is gonna run like the same speed it runs when u put all the weight because ur putting more power but ur using the power to pull all that weight
Xmod:
Civic (black)
Stiff Suspension
Awd
White side skirts,White Carbon fiber hood,White rims and Drop
Old 01-03-2004, 03:20 AM
Gaian's Avatar
For the 5-cell, just remove one of the extra batteries and run a jumper between the 2 contacts (like a wire w/alligator clips on each end or something like that)
Right now it's running on RS Enercell Plus (waiting to get a charger for my IC3's) and the stock motor (Stage 1 w/8 tooth) and it flies!!! (those extra 2 batt's make a huge difference) Can't wait to try it with a stage 2 blue and the IC3's.
Got bored today...added a 6th cell HPIracer XMODS Mods and Projects 2 01-12-2004 04:45 PM
Got a zip zap today and it doesnt work!? Whatup1049 ZipZaps 5 12-29-2003 04:47 PM
got mine today, but car keeps turning left no matter what i do badazzTL XMODS 6 10-24-2003 11:36 AM
Yokomo Puchi Maru 4 sale P/P today only! Grampa For Sale/Trade 1 09-12-2003 02:03 PM
F&F2 items show up today at RS Grampa ZipZaps 1 05-10-2003 07:21 PM
