Old 10-07-2002, 04:26 PM
n2bits n2bits is offline
more voltage for the remote
If you use 2 batteries on your car for a total of 2.4V, them could you rewire your remote to run on 2.4V? Then you could recharge the car and maybe get more range!
Old 10-07-2002, 09:03 PM
r.c.dealer's Avatar
r.c.dealer r.c.dealer is offline
deviant bit char-g pro
der?
Since your transmitter(remote) uses 2 AA alkline batteries that are 1.5 volt each, your remote is allready being powered by 3 volts.
So what would be the point of reducing the voltage? I think you talking about adding an extra battery to the remote, which would bump the voltage up to 4.5 volts.
Old 10-07-2002, 11:31 PM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
The remote uses 2xAA batteries, which comes out to 3.0v (if you use Alkalines). That's what is fed to the controller...But the electronics squeeze it down to 1.5v when sending to the charger.
You could put 2xAA NiMH batts in your controller, that would juice it down to 2.4v...but less juice in the controller means less juice to the antenna (less range)
Low Voltage Warning Light Rez XMODS Mods and Projects 3 02-06-2004 11:42 AM
Rechargeable Li-ion adjustable voltage mod actofgod Bit Char-G Mods and Projects 5 12-03-2002 04:34 AM
AC-to-DC adapter for controller gRC ZipZaps 50 11-18-2002 10:19 PM
NEW ON REMOTE CHARGER for duel cell teamyoshi ZipZaps 2 10-12-2002 06:01 AM
more voltage for the remote n2bits Bit Char-G / MicroSizers 1 10-07-2002 11:38 PM
