Old 12-15-2003, 02:35 PM
FrozenKamikaze's Avatar
FrozenKamikaze FrozenKamikaze is offline
Don't point at Me!
Good Drift setup?
I kinda need to know i just installed the Drift motor(Stage2)and i'm running hardtread all the way around and i have yellow springs all the way around......is this good??
Oh yeah this is kinda off topic but do any of you know of any good Larger scale nitro rc message boards?? I'm also getting into Nitro and i would like to learn more.
Thanks a bunch!
Black Honda Civic coup
Rechargable batt upgrade.
Command Logic light kit.
Stage2 Drift.
Tire upgrade.
Steering & Suspension upgrade.
1.5 steering rod.
Yellow springs all the way around.
Soon to come: Body kit
Old 12-15-2003, 02:57 PM
pacificwarriors's Avatar
pacificwarriors pacificwarriors is offline
MY ENZO!!!!!!
What kind of nitro car?
Old 12-15-2003, 02:59 PM
Don't point at Me!
A Traxxas Rustler stadium truck.
Stage2 Drift.
Tire upgrade.
1.5 steering rod.
Old 12-15-2003, 04:21 PM
XMODADDICT
drift>
red springs in front, blue in back
soft tires in front, hard in back
batteries set to the back
hope this helps you
Old 12-15-2003, 10:43 PM
Don't point at Me!
I'll try that out.
Stage2 Drift.
Tire upgrade.
1.5 steering rod.
Old 12-17-2003, 06:53 PM
charliebrown's Avatar
Here's what I think.
You will need hard springs in the back, mediums in the front, and you may want to try the Stage 1 upgrade kit. People have spun out becuase they've had TOO much power. You're gonna need more traction in the front than the rear. Do not confuse drifts with powerslides. http://streetracing.tiora.net/japan/drift/drift1.htm is a good page to explain drifting, but that's for real cars....It should, however, give you good info on drifting.
RS Stg II 12 25 setup jnkyrdstng XMODS Mods and Projects 0 03-02-2008 01:31 PM
Stock ZZ drifting? Elpizo ZipZaps 6 11-06-2006 08:04 PM
Drift Setup yanra5 XMODS 6 06-27-2006 10:34 AM
what is the best drift setup badsupra1239 XMODS 1 11-04-2003 04:47 PM
Boosters are good drifters! Zephyranthes Bit Char-G / MicroSizers 2 04-02-2003 12:56 AM
