12-07-2003, 12:03 AM
xmods steering noise question
what are the normal sounds for an xmod when turning the front wheels a grinding sort of sound? mine works fine as far as i know but i've never heard an rc car make this type of noise
12-07-2003, 01:40 AM
modSquad Member.
Yes, if it is a loud beeping sound. It is your car, it is perfectly normal, its the servo.
White '97 Toyota Supra
Mild front, wild sides, stock back
Stage II motors
Hard suspension
Black painted Enkei wheels
Command Logic lights (Courtesy of http://www.xmodrc.com)
In the process: XMOD Dynamometer (DYNO)
12-07-2003, 03:15 AM
no its not a beeping at all more of a grinding/ticking sound but stops when the wheels are turn all the way left or right and they dont shudder so i guess its normal? it just seems a bit loud
12-07-2003, 10:01 AM
Acura RSX
I guess there is no harm done. As long as it runs how it should, then it is alright.
12-07-2003, 11:32 AM
I'm not a pyro, really.
some dirt may have gotten in
NEVER UNDERESTIMATE THE POWER
12-07-2003, 02:09 PM
Jebus, that sound is normal for an Xmod. The Xmod's steering servo isn't truely proportional. Most (actually, nearly all) hobby grade RC cars use a servo with say 45 degrees of travel. Those 45 degrees will be divided an infinite number of times. On an Xmod, that 45 degrees is divided 16 times. Every time you hit one of these 16 positions, you hear it click, so it sounds like it's grinding, but its not.
dB
12-07-2003, 03:56 PM
0reZepyT
well it's not infinite although it feels that way, it's either 512 (typical) or 1024. our xmods won't really turn the wheels 45 degrees, it's a little less than that, haven't measured it but just by eyeballing it, it's not 45 degrees
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
12-07-2003, 04:31 PM
Put Custom User Text Here
yea. its not quite 45 but that sound sounds kindof normal
12-08-2003, 01:19 AM
thanks alot guys im just not really familiar with "proportional" r/c cars i've only messed with zip zaps and microsizers and the occasional large r/c truck/car
12-08-2003, 08:10 PM
HEY!
THE SE ZIPS HAVE THE SAME SOUND! exept the zip steering
servo is just a zip motor and a gear that is connected to the wheels possibly... R.S is incorperating the same technology in
their cars im not sure how a normal steering servo works but
i think its either a magnet or a motor that is DIRECTLY linked
to the wheels...
mini z:ferrari f-40
xmod:body undecided
12-27-2003, 01:35 PM
I hit a wall really hard w/o the body.
Not it doesn't turn well when in motion.
Help! If it's a simple easy fix, I can do it.
I just got it today, so I on't hesitate to return it.
12-27-2003, 01:45 PM
Your best bet might be to just go ahead and return it to be safe. You probably stripped the servo gears. Does it turn at all when you hold it in the air? Be a little more specific about what it is doing.
12-27-2003, 11:23 PM
Should I get NiMH or NiCD or whatever? I don't get what the differences are. What is best for Xmods?
