Old 12-01-2003, 12:06 AM
ph2t's Avatar
ph2t ph2t is offline
Chief Propeller Head
Guitar String Antenna for your ZZSE
Pretty much all you need to do is goto a music store and ask for a Number 9 electric guitar string. If they ask more questions just ask for the "bottom E" the lightest string on the electric guitar.
You need to pull apart the zzse and remove the rear plastic "knob" that holds the pcb down. You will also need to remove the front plastic facia that covers the pcb there as well.
Remove the old antenna and notice where the solder point is. What you want to do is "pre-bend" the string to follow the path of the original yellow (mine was yellow) antenna. See below:
Before bending I put some plastic wire sheath from some hobby wire over the string. I dip the end of the string is a tiny bit of superglue and then feed the wire into the sheath. This allows the plastic cover to stick to the wire and then you can bend it to the shape you need as shown in the picture above.
The following pic gives you an idea of the length, approx 12cm.
Make sure you put a protective cover over the end of the string or at least curl the end around to protect your eyes!
The final pic below shows you how I ran the antenna though the hole of the plastic holder knob thingy......
Hope this works for you. This mod increased the range of my zzse bigtime!
ph2t.
Old 12-05-2003, 07:39 PM
xc/zz
Cool
I play guitar but I never thought of that. Great idea!
I'll try it!
Old 12-05-2003, 08:22 PM
xc/zz
Does the wire never fall off?
Old 12-05-2003, 08:34 PM
ph2t's Avatar
you mean does the wire EVER fall off? no, it does not.
but if you do a crappy job of soldering it then it will.
your question can only be answered by how well you solder the antenna to the pcb.
ph2t.
Old 12-05-2003, 08:56 PM
xc/zz
Will the guitar string solder on?
need a new TX antenna? TypeZer0 XMODS Parts and Hop-Ups 3 02-15-2004 07:09 AM
Alternate antenna ideas! caver01 Bit Science 214 11-07-2003 09:38 PM
Antenna Support System got BITS? Bit Char-G / MicroSizers 7 03-27-2003 11:25 AM
ZipZaps: Antenna Mod pics available in Gallery Namuna Bit Char-G Mods and Projects 2 09-25-2002 11:13 AM
Guitar string steering replacement blacksabbath070 Bit Char-G / MicroSizers 2 08-03-2002 02:12 AM
