Old 11-27-2003, 08:42 PM
Caseman Caseman is offline
car wont turn please help
I got the car yesterday and used up the first set of batteries. I put in the second set and the car wont turn? I dont think i dropped it or anything?
anybody have any idea?
could i take it back to radioshack?
how are they on returns?
o ya.. i installed the awd kit also
thanks for any and all help
Casey
Supra
-awd
-SB-H
-6 Cell
Old 11-27-2003, 09:22 PM
weba2nkill3r weba2nkill3r is offline
teenage r/c maniac
Send a message via AIM to weba2nkill3r
it is the controller. my friend had the same problem too. so.....we changed crystals n then it was fine . u have to return it
Old 11-27-2003, 10:06 PM
ahh so is this fix free?
or do i have to buy new crystals?
Thanks
Casey
Supra
-awd
-SB-H
-6 Cell
Old 11-28-2003, 11:35 AM
teenage r/c maniac
90 day warenty!
Old 11-28-2003, 11:40 AM
CurryITR CurryITR is offline
Lightbulb DONT TAKE IT BACK
the problem is the awd, the red limited slip differential in the back of the car when you put the awd in messes it up. just put the stock white diff. in the back
Old 11-28-2003, 11:55 AM
viperkilla's Avatar
Acura RSX
Re: DONT TAKE IT BACK
Yea that happened to me. Just place the white one. It meshes alot better, than the AWD one.
Old 11-28-2003, 12:11 PM
aero528's Avatar
aero528 aero528 is offline
like my dog??
Send a message via AIM to aero528
there could be two totaly different problems here it could be the awd or the controler. reinsert both cyristals. set STRANGE to MAX. do the fornt wheels even turn?? if they dont then it prob. the controler.
--Chris
Aka...aero528
Old 11-28-2003, 01:44 PM
kasper01001's Avatar
kasper01001 kasper01001 is offline
("\(0.o)/") Rawr!
Send a message via AIM to kasper01001
same prob happend to my friend when he installed the AWD kit, we started noticing that it took too long for it to turn, he told me he changed the tierod and it helpd. so i guess that will work. any suggest?
Xmod Parts Help
Old 11-30-2003, 10:00 AM
I took it back the guy at radio shack poked around with it for about 15 mins. Then he said it could be the streering motor he said " here just take this (demo car) home and take out the streering motor switch it with yours. You have been in here a few times i trust you". so i take it home take it all apart and see that the connections are not comeing off with out cutting them. take it back the guy says take off the awd and i will give you a new car.
That made me happy
I hope it will be this easy when something breaks in the future
Thanks for all the replys
Later
Casey
Supra
-awd
-SB-H
-6 Cell
Old 11-30-2003, 06:08 PM
badboy007 badboy007 is offline
When I got my Xmod It wouldnt turn. I didnt know that so I
drove it on a table and it crashed into my cow and the cow got mad and hit it with its bell.After that my Xmod could turn but it
could'nt go foward.
Old 11-30-2003, 06:10 PM
viperkilla's Avatar
Acura RSX
could'nt go foward.
Do you live on a farm or something?
Old 12-01-2003, 12:21 AM
livingplasma livingplasma is offline
My second XMod (the RSX) turned pretty slow. Since I couldn't return it (raised the body for front wheel clearance), I decided to mess with the servo. It's hard to describe, but inside there's this slipping function on one of the gears in there that allows the servo to be loose if the opposing force on it is too great. It's like a gear with teeth on the inside and a smaller gear fits into it, the smaller gear being connected to the shaft by plastic spoke "springs" so it can move in and out. I took one of the plastic bushings and used it as a buffer as i tapped those two gears further down the shaft and it tightened it up. I might have to do this to my Skyline as well since it's starting to turn slow in one direction (you can hear it slipping (makes kind of a grinding noise)as it turns left at a standstill). If you don't want to go that far with repairs, then just return it for a new one =)
Old 12-01-2003, 09:22 AM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
take the steering servo apart and clean it out. a piece of dirt or something could have gotten in there. its happend to me on numerous occasions
NEVER UNDERESTIMATE THE POWER
ABC CRP problem: Turn left when accelerate ikinari ABC DTM Electronics 25 05-10-2004 03:04 AM
Tuning Basics sperry XMODS Parts and Hop-Ups 12 11-19-2003 01:56 AM
Car wont go backwards... Drag00n Bit Char-G / MicroSizers 3 11-15-2003 12:56 AM
Cat5 vs Cat5E for car antenna material mechanist ZipZaps 6 10-13-2002 01:59 AM
