Old 10-03-2002, 09:44 PM
go_zz_go's Avatar
go_zz_go go_zz_go is offline
more power!!
? about dual batt mod
do you have to mod the charger to get it to fully charge
Old 10-03-2002, 09:48 PM
blacksabbath070's Avatar
blacksabbath070 blacksabbath070 is offline
IRON MAN OF BIT RACING
hmmm
good question you charge it for 180 seconds
MY NEW CUSTOMIZED BIT:
red ae86 with zipzap spoiler
carbon fiber hood
3.8 motor (well, it doesnt want to run now)
qfm springs
back wheels on front and back
8.25:1 gearing
rare earth magnet steering
Old 10-03-2002, 09:50 PM
ax0n
if you wire them in parallel, you shouldn't have to, but you may want to charge it twice in a row. If you wire them in series, then you won't be able to fully charge them (I.E. up to 24 volts) but either way it'll still increase the amperage, which is where the ZZ's are hurting compared to the bits.
If you wire them in series you'll have to find a way to put about 4 volts (I believe) across the charging terminals.
Old 10-03-2002, 09:51 PM
go_zz_go's Avatar
more power!!
thanks do you just leave it on after the light goes out? or restart it or just count sorry im as clueless as alicia silverstne (errr HOTT!!)
Old 10-03-2002, 09:52 PM
go_zz_go's Avatar
more power!!
ok yall answerewd my ? as i was typing thanks every one
Old 10-03-2002, 09:53 PM
headhunter555 headhunter555 is offline
The Lexan Body Pro!
I may be wrong(i dont think i am though) but if u wire them in a series u are gonna fry the board cuz its twice the voltage it was ment for.
~~~Bash it Bash it Good!!!~~~
Old 10-03-2002, 09:58 PM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
Ummmm...
Wired in Series = Higher voltage, more power to the Motor and faster.
Wired in Parallel = Higher Amp, more current and longer runtimes.
There's a reason why they call the dual-battery mode the 2.4v mod as well.
Old 10-03-2002, 10:07 PM
Axel's Avatar
Axel Axel is offline
Send a message via Yahoo to Axel
headhunter555,
Nope, this board can take a ton more than the 1.2v stock. I was running it off of a 9v for a couple minutes with no problems at all. Voltage is the key to hotrodding the ZZs.
-Axel
+Red RX7 ZipZap
-Dual-cell mod (2.4v)
-Antenna mod (100+ feet outside!)
-green ground effect LED ligthts mod
Old 10-03-2002, 10:18 PM
go_zz_go's Avatar
more power!!
thanx for every thing i had to put my son to bed and come back to a plentiful supply of answers now one ? again i found there is plent room for three batteries aso let me run this by you all
three in a series= 3.6v right so is that three times the charge and i did that 9volt batt man it would kick road if we could get nine volts in a smaller package any i am not scared of frying it so should i go to the shaq and get the same stock battery ni-mh
love this forum tons of great info
Old 10-03-2002, 10:19 PM
The Lexan Body Pro!
cool ill have to give 2 batterys a shot then.
Old 10-04-2002, 12:04 AM
cdo cdo is offline
Hi everyone new here.
Can someone explain the difference between wireed in parallel and series?
Thanks
Old 10-04-2002, 12:22 AM
The Lexan Body Pro!
ok parrallow, is when u wire Red to red and black to black, this way the voltage is the same wether u have 1 battery or 2, BUT with 2 batterys wired this way the run time will double.
In a series is when u wire the possitive of one battery to the negitive of the other battery and then the remaining possitive to the hot and the remaining negitive to the ground of the board. This will mean havng the same runtime, but double the power to the motor, wicth mean the car will be almost twice as fast.
if that does not make sence lmk ll try to explain it better.
Old 10-04-2002, 12:25 AM
ax0n
Parallel:
you get the same voltage, 1.2V even though 2 batteries are there, but it cranks a LOT more amps, it doubles the amperage output, this is where the Zip Zaps are really lacking.
Serial:
This ups the amps a little too, but not as much as parallel would. more importantly, it DOUBLES the voltage. If each of those batteries in the serial pic were 1.2Volt cells, the circuit would be getting 2.4 volts.
get it?
Old 10-04-2002, 12:29 AM
cdo cdo is offline
cool thnx alot guys, I dont know very much about electronics, thats why I run nitro R/C cars, with gas engine I am OK.
Old 10-04-2002, 12:37 AM
Namuna's Avatar
Hulk smash!
Here's another look...As the rule of thumb, add volts in Series, add amps in Parallel.
w/ a dual batt. mod...wich sould i use 2.6 or 2.8 jutte07 ZipZaps 2 01-05-2003 12:44 AM
dual batt mod w/o soldering to car. JTM Bit Char-G Mods and Projects 4 12-31-2002 04:54 PM
dual batt mod with two 100 mAh nimh battery I2ed ZipZaps 2 12-19-2002 10:49 AM
Does the Dual Batt Mod also work with Booster Maschine Jorgw Bit Char-G Mods and Projects 1 12-05-2002 11:44 PM
Dual Batt. Mod stevensmd3 ZipZaps 13 11-16-2002 04:03 PM
