Old 11-03-2003, 11:43 PM
EMX's Avatar
EMX EMX is offline
I R r33t Hick
Send a message via AIM to EMX
Painting Questions
ok im in the process of painting my skyline
i just got done with the fron bumper and I need your opnion on the color...
as you can see, i suck at the masking so i used a sharpie to "fix" the problems....
now i know i can mask better, but even if i try hard wile painting the rest of the car and I get a line, is there a better way to fix the "lines" then with a sharpie?
also what do you guys think of the color?
its Mica Blue with a couple coats of black primer under it.
Old 11-04-2003, 12:32 AM
dragon4450's Avatar
dragon4450 dragon4450 is offline
customanix
Send a message via AIM to dragon4450
i like the color but i would put a clear coat on it just to make sure that you have a nice gloss to it. also try to file down the notch on the bottom of the bumper it looks ok just needs to be cleaned up a little. and use real black paint to clean up around the edges. you can pick up a good fine paint brush for about a doller.
and then we added the giggle gas.
Old 11-04-2003, 07:35 AM
neurokinetik's Avatar
Mad Scientist
Color looks good so far...
I touched up my seepage using a really fine paint brush and some Testor's gloss black paint. It matches better than a Sharpie.
You will get less seepage with the blue masking tape than the normal stuff, and it also works best if you don't have to layer the tape at all. (The stuff I use is 2" wide)
Old 11-04-2003, 08:23 AM
EMX's Avatar
EMX EMX is offline
I R r33t Hick
with the primer i didnt get any seepage,
my problems all lie with me masking too much then when im done painting i have a yellow line where i over masked.
Old 11-04-2003, 08:53 AM
Mad Scientist
Yeah, I see what you mean now. Either way, the Testor's gloss black is a perfect match for the black on the rest of the car.
Old 11-05-2003, 12:34 AM
CtrlAltDel CtrlAltDel is offline
im just buying car paint and some clear coat for it
contacting my car paint site today to get me some Bayside Blue (TV2) paint for my skyline
Old 11-05-2003, 02:36 AM
dragon4450's Avatar
customanix
use an exacto knife or a hobby knife and trim it down after your done laying it out also if you use a small flat screw driver to make sure it pressed in all the way in the holes it will make it easier for you.
Old 11-06-2003, 08:46 AM
EMX's Avatar
EMX EMX is offline
I R r33t Hick
Almost done
hehehehhehehehe
just gota clear coat the body and re-asemble it
Old 11-07-2003, 01:16 PM
vawax vawax is offline
I'm new to the site, AND to customizing these cars. Can someone give me the basic run-through on what paint is best, primer or no? , how many coats, and how to make custom decals. I know it's a lot, but you guys seem to know a lot about what you're doing.
Painting a ZZ rody ZipZaps 3 11-07-2006 09:51 PM
questions about painting gorbasho XMODS Parts and Hop-Ups 7 04-12-2005 08:20 PM
2 simple painting questions RacinSkillZ101 XMODS Gallery 2 07-26-2004 10:10 PM
painting questions krillin52 Bit Char-G Mods and Projects 0 01-10-2003 02:33 PM
