10-27-2003, 11:48 PM
servo actining strange
my steering servo wont turn to the left unles you have the wheel all the way to the right and turn it back to the left fast it will move most of its range but when it gets like two clicks from center it returns to not working. i thought it was dirt between some parts so I took the front stuff of and the arm that is on the servo and same prob guy at radio shack said he wouldnt replace it cause it was wrecked and i wrecked it bc the servo wouldnt turn
any ideas as to what might be the problem?
my car is white supra 9 tooth stage 2 awd bearings
10-28-2003, 12:15 AM
same with my white supra. i took off the claw thing on the supra, turned it on and let it center then put the white claw back on, but didnt help
10-28-2003, 12:36 AM
I have a beach ball...
Try opening it up and cleaning it out. It may help.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
10-28-2003, 03:23 PM
thought it might void the 30 day?
10-28-2003, 03:41 PM
my civic did that and i coudlnt fix it so i would return it if i were you it greatly effects driving
10-28-2003, 04:20 PM
yeah, return it if you don't want to void the 30 day return.
'65 Ford Mustang
All the RS goodies
10-28-2003, 05:32 PM
so i returend my civic and now this one is doing the same thing this is pissing me off
my rsx has had no problems it just runs a little to the left
10-28-2003, 06:46 PM
they wont take it back bc i wrecked it
i wrecked it bc i couldnt steer it
but that was olnly some lowley salesman i talked to not the manager
10-29-2003, 10:42 AM
10-29-2003, 11:35 AM
Got Mini-z?
if its 4wd then check and see if the servo stick thing is toching the diff when you turn left or right...
10-29-2003, 11:37 AM
Mine did it before the AWD kit. The radius is horrible compared to my friends skyline...
10-29-2003, 11:47 AM
You might try changing out the steeing rod to one of the upgrade ones and see if it does the same thing. What does the servo do when nothing is on the front end does is work correctly? Also did you ever test you car out before you added the upgrades?
10-30-2003, 09:08 AM
fixed
my servo was the problem there are a series of gears and one is on splines it was off true i took apart the servo and found out that was my problem after thinking it was binding on the case
