Old 10-21-2003, 04:08 PM
thecoopie thecoopie is offline
Unhappy BROKEn
When i was doing the steering upgrade i took the whole front of the cra aprt and now i can not get it back together. If you have the answer please e-mail me at thecoopie@aol.com Subject XMODS.
Thanks
Old 10-21-2003, 04:18 PM
viperkilla's Avatar
Acura RSX
Well cant you just use the directions to figure how to put the car back together?
Old 10-21-2003, 04:22 PM
NO
IOt is not in the directions
Old 10-21-2003, 04:42 PM
I have a beach ball...
umm, what exactly are you having problems with?
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 10-21-2003, 04:43 PM
slugbugg slugbugg is offline
I KNOW NOTHING!!!
Its not that hard.
start by finding the directions then carefully lay the parts out roughly how they go.
Once you have the parts layed out close you will start to see how it all goes together.
tierod has to be installed before uprights.(the uprights are labeled R / L)
suspension arms have to be properly attached to the uprights before attaching uprights to chassis.
that black axle spacer has to be properly postioned through the uprights before attaching second upright.The steel shaft is to the left of the little finger on this if you are looking straight down at the car with the back facing you.
The steering knuckles/spindles go on only one way, there is a left and right(not labeled).the pin coming up from the tierod end goes through the slotted hole. on the spindle, the long pivot pin (kingpin)goes down and the ball shaft goes up.make sure you have the steel axles and bearings/bushings installed.
dont worry about shocks untill last but make sure the a-arms are right early on so you will be able to attach shocks.
Old 10-21-2003, 08:34 PM
Savior*insider Savior*insider is offline
AHAHAHA im sorry... thats friggin funny. u could always buy another one and use it as an instruction model
I am the insider, i kno all
current xmod stats: everything. i got the hook up =P
pcb cover broken? frizzen ZipZaps Monster Truck 4 07-18-2005 02:55 AM
Broken rear tab dje7447 Bit Char-G / MicroSizers 2 01-07-2004 09:19 PM
Help with broken car... skyline0276 Bit Char-G Parts and Hop-Ups 4 11-09-2002 10:48 AM
broken bit xsboost94 Bit Char-G / MicroSizers 2 10-01-2002 09:13 AM
Broken chassis BaliLover Bit Char-G / MicroSizers 7 07-14-2002 11:40 PM
