Old 10-21-2003, 12:53 PM
k2zed
Bearings will they work in a mini-z?
Just wondering if they would work in a mini-z. It would just be easier for me to pick some up at rs than have to order away. Thanks
Old 10-21-2003, 02:13 PM
k2zed
are the wheels the same size?
Old 10-21-2003, 02:46 PM
adroit adroit is offline
The Xmods bearings are 6mmx3mmx2mm, I believe a mini-z uses 6mmx3mmx2.5mm, which means the smaller bearings probably work. The last number is only the width of the bearing.
Old 10-21-2003, 06:58 PM
maxximum attack
are the mini-z bearings sealed?
Old 10-21-2003, 08:13 PM
oOfrog_BoyOo oOfrog_BoyOo is offline
Poopie monster
Send a message via AIM to oOfrog_BoyOo
Hey will it work the other way around miniz bearings into xmods???
wat
Old 10-21-2003, 10:26 PM
I don't own a mini-z and I'm not sure if the bearings are sealed or not. As for fitting them into an Xmod, they are wider than the RS bearings, but the XMod might allow enough room to sqeeuze them into at least some spaces.
Do you think these bearings will work? _revhards13 XMODS 11 10-22-2003 12:37 AM
will this charger work??? (mini z) mxnjk TTTT 1 09-18-2003 05:57 PM
