Old 10-21-2003, 10:18 AM
Mazultav Mazultav is offline
Send a message via AIM to Mazultav
Dos Questions Por Favor
2 questions
1. What are U-Joints and what are they usded for?
2. Will any AM Tx transmit on the AM X-tal that it has installed?
Like if i put an Non-27MHz Xtal in a traxxas radio will it transmit on that freq?
Old 10-21-2003, 07:01 PM
egdinger egdinger is offline
don't know really how to explain u-joints, but on the radio, yes I belive so, but rande and glitchyness will be alot worse and you will probably be breaking a law (or several) and there is no way your going to get a traxxas revicer in one of these.
Old 10-22-2003, 06:36 AM
fastboy fastboy is offline
im a micro daddy...
Send a message via Yahoo to fastboy
ujoints(universal joints) are used when the drive train needs to go thru any angle more than straight,in effect it lets you "bend" a straight bar while still allowing it to turn,this is needed on a steering assembly when the front wheels are powered by a motor.
dave
Old 10-22-2003, 10:59 AM
I know i cant fit a traxxas reciver in it, but i can use the transmitter and transmit to a GWS mini reciever right
Old 10-22-2003, 03:53 PM
killer's Avatar
killer killer is offline
Proud to be Pinoy :)
Smile
:ö: according to my dictionary, a universal joint is a joint or coupling that allows parts of a machine not in line with each other limited freedom of movement in any direction while transmitting rotary motion. Also called universal coupling
about your radio... i heard somebody tried using different frequency on a 27mhz AM radio and did well.. but i suggest you just use what the radio requires so you won't have any trouble
hehehe
Old 10-22-2003, 10:49 PM
Hitec makes channel conversion crystals, i was thinking of using their Feather 4 Rx (about same dimensions as GWS 4-channel) with the Hitec crystals in my Traxxas Tx
questions questions questions kasper01001 XMODS 12 01-02-2004 04:38 PM
Bit-Dub Conversion questions mcojoc Bit Char-G Mods and Projects 4 09-25-2003 10:02 PM
Bit-Dub Conversion questions mcojoc Bit Char-G / MicroSizers 0 09-25-2003 11:49 AM
Questions for Ahh5hit 55_BrOoKs_55 ZipZaps 8 08-25-2003 07:27 PM
Few questions CjsF150nNeon Bit Char-G / MicroSizers 13 02-03-2003 12:16 AM
