Old 09-29-2002, 10:39 AM
Def Def is offline
ZZ's body are TOO heavy!!!!
Was wondering why my ZZ w/ a NOS motor was running like crap until I took off the F&F body and realized how thick that thing was. Without the body, the car goes forward and reverse very fast and can manuever VERY well. I plan to somehow sand the inside of the body down to make it thinner or replace it all together with something lighter. But if you buy a ZZ, definately consider modding the body! It is just TOO heavy.
Old 09-29-2002, 11:59 AM
cowfish_29's Avatar
yellow fish forever!
i was thinking about DansAm bodies...then you could make em reallly low...it would look good with those kind of wheels. especially if you painted the rims silver or something...
Old 09-29-2002, 12:02 PM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
You might want to hold off on the DansAm bodies...Unless they came out with a 'HO Scale' body set.
As is (AFAIK), that body set is intended to fit Bits...NOT ZZs.
Old 09-29-2002, 04:54 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
i was gonna cut out all the side windows on my eclipse
Old 09-29-2002, 10:04 PM
kwikbb's Avatar
kwikbb kwikbb is offline
smoove operator
Yeah i definetly agree about the body being heavy, i tend to take it of most the time. Just put in a 120mah NiMH in today, a couple of good points:
It's smaller so it's also lighter... much lighter
A single charge gave me about a 10-12 minute run time (I shut it off after about 5 minutes... was getting board . Then about 10 minutes later I turned it back on and ran it for at least another 5 minutes
Also seemed a tad bit kwiker (Still running a 1.6 )
Old 09-29-2002, 10:28 PM
VDOGG VDOGG is offline
Does anyone know if H.O. scale slot car bodies will fit zip zaps?
-Vince
Old 09-29-2002, 11:11 PM
JediYoda56 JediYoda56 is offline
Send a message via Yahoo to JediYoda56
I was just thinking of using HO slot car bodies. Mostly likrly lexan ones as they are really light and you can cut any holes into them you like. Mounting one of them should be easy as the ZZ's should be the same size. I just can;t get any HO lexan bodies right now my hobby shop only had the 1/32 sizes. grrr.
Old 09-29-2002, 11:57 PM
headhunter555 headhunter555 is offline
The Lexan Body Pro!
hehe yeah i had to try it once i read the post and ur right it on the edge of being balistic! thats wiith a 1.6
~~~Bash it Bash it Good!!!~~~
Old 09-30-2002, 09:00 AM
kwikbb's Avatar
smoove operator
-Vince
Yep, 1/64 scale bodies will get the job done.
Old 09-30-2002, 05:08 PM
NorCalCoug's Avatar
NorCalCoug NorCalCoug is offline
l33t camber wizard :)
Re: ZZ's body are TOO heavy!!!!
The dremel 0wNz j00.
Heck, I dremelled out the inside of my Bit's body (RX-7) and dropped about 30% of the weight, easy. I'm sure you can do it with a ZZ too. I think I might pick a couple of them up this friday to mess with them.
BC's Xmod Masking/Painting Tutorial Bad Company XMODS Mods and Projects 30 07-15-2007 11:13 PM
Austin Martin DB5 body issue (a warning & a fix) rc+bass ZipZaps SE 13 05-23-2006 12:19 AM
Body Filler and Body Kits spamman ZipZaps Mods and Projects 2 02-18-2004 01:48 PM
WTT: wanted: nissan gloria gunmetal body blght For Sale/Trade 5 03-08-2003 10:44 PM
package body mod dtmracer ZipZaps 7 10-20-2002 09:03 PM
