Old 10-14-2003, 10:42 AM
mbartell mbartell is offline
so I re-wired it
glitching
Anyone tried a capacitor to make the steering glitching stop? It wouldn't be a problem in the normal zip zaps, but the se's have to be a lot more complex and sensitive.
I was going to try and cut the wire, but I only have a 2 wire pot.
ah well.....
Uhh, gee thanks Radio Shack.
Famous last words:
Hold my beer and watch this
Old 10-15-2003, 12:54 PM
wild03 wild03 is offline
Re: glitching
ah well.....
I assume that on the two wire pots they are making the bridge on the board instead, They probably figured that they could save the extra wire running down to the pot but doing the bridge(Hack) on the Board instead ! I'm sure you can convert a 2 wire pot to a 3.
Old 10-16-2003, 08:45 PM
T_T_52
My savana rx7 has the gliching problem but I don't want to kill it or its 90 day warrenty. these se body tabe holes are too low which makes it raised.
__________________________________________________ __
I'M BACK
Glitching Prolems... Yugo DSC Maxxer Bit Char-G / MicroSizers 6 09-18-2003 04:18 PM
glitching precious VuN86 Bit Char-G / MicroSizers 1 03-27-2003 08:12 PM
mini-x versions sleepyb Mini-X 55 10-22-2002 10:36 PM
