Old 10-11-2003, 02:47 PM
Draconious Draconious is offline
Send a message via AIM to Draconious
Xmod Wheel Base & Width ?
Can some one list a few dimmension of the XMods?
* the WIDTH of the chassis outter flush of rims...
* Wheel base lengths? (center front axle to center rear axle)
I need to know how well if at all the bodies may or may not fit my 4WD Mini-Z Chassis... (comming soon, but likely too late now that the xmods are 4wd). I want to make these bodies fit my chassis design as well as the Racer and Overland bodies... even if it needs a kit to fit the rear body posts.
Old 10-12-2003, 08:56 PM
CharlzO CharlzO is offline
Wheelbase is 3 11/16" long, center to center. Width is 2 5/8" from outer rim to outer rim. I'll try to get a pic up tomorrow showing the underside of the stock body, showing the two mounts. There's a slot-mount in the front (the chassis has a tab that slides into the front first, then has a catch-style hook in the back that it comes down and hooks with in the back.) hard to describe in words. hope it helps!
Old 10-13-2003, 04:04 PM
3series takumi's Avatar
3series takumi 3series takumi is offline
mini-eX-Driver
Send a message via ICQ to 3series takumi Send a message via AIM to 3series takumi Send a message via Yahoo to 3series takumi
does anyone know the diameter of the rims? and or width! curious about fittin some miniz tires to that thing
soon to be
mini cooperS (bmw) mini-x
novak xxl receiver
lrp quantum micro esc
hpi micro mod
5 2/3a zapped cells
novak 10v 4700u power cap
xmod suspension
xmod wheels and tire upgrade
Old 10-13-2003, 05:27 PM
if no one beats me to it, I'll measure tonite. (and I'll try to get that mounting pic too)
Old 10-15-2003, 01:58 AM
So its the same as a Mini-Z (MR01) in the LONG setting well that solves the wheel base problem... the body will fit... but how does the side/front mount? I should be able to adapt them easily... to my AWD chassis...
Old 10-25-2003, 04:39 PM
mini-eX-Driver
now i know that there are 3 different wheelbases, what is the size of the longest one (the skyline i am assuming)
soon to be
novak xxl receiver
hpi micro mod
5 2/3a zapped cells
xmod suspension
Old 10-25-2003, 05:03 PM
Bad Company's Avatar
3-3/4"
Old 10-25-2003, 05:27 PM
k2zed
the front mounts the same, you will just have to add the pieces on the sides of the body to fit a z, not sure how the overland bodies are though.
Spec 1 wheel base slotsurfer Epoch RC1/43 14 09-02-2006 03:53 AM
car differences (mostly wheel base) n2o_matt XMODS 3 12-12-2004 08:57 PM
Can you make an XMOD FWD?? (FRONT WHEEL DRIVE) jamiekulhanek XMODS 3 06-04-2004 12:24 PM
just lost a wheel and two NEW metal wheel nuts... impression_xmod XMODS 1 04-22-2004 05:54 AM
FWD XMOD!! YES! Front Wheel Drive!! MicroRCracer XMODS Parts and Hop-Ups 60 01-14-2004 03:32 PM
