09-20-2003, 09:19 AM
C:\WINDOWS\DESKTOP\
Savanna lowering
Please forgive me for asking the same question a million times but how did you guys lower the savanna so much. I just got mine and it really does sit really high n the front
And that's my word and i'm stickin to it.
09-20-2003, 09:22 AM
Actually, they suck^
I 2nd his post
1 Xmod w/ the works
2 Microsizers
1 Zipzap
1 Zipzap SE
1 Toy East Mini Cooper
1 Precious Clone
09-20-2003, 10:43 AM
If you want to get it really low, you have to remove/move the light system PCB under the body. Other than that, you perform the teb lowering. The one I did, I just removed the existing tabs and because of the tight fit with the skirts I added, the body stayed on nice and fit just from the tension, but I will add the tabs later.
See my lowering with and without the lights removed here...(Page 4 on...)
http://www.tinyrc.com/forums/showthr...5&pagenumber=4
09-20-2003, 01:37 PM
badcompany,
when you lowered the tabs, what did you cut them off with? Did you reuse the tabs or something new? Finally, what kind of glue did you use?
1 Xmod w/ the works
2 Microsizers
1 Zipzap
1 Zipzap SE
1 Precious Clone
09-20-2003, 02:24 PM
I cut them oof with a dremel. After using the bit I use, there is 1/32" less tab left. I use a credit card to replace them with and just plain ole' Krazy Glue.
Tab Lowering
09-20-2003, 04:14 PM
thanks BC
1 Xmod w/ the works
2 Microsizers
1 Zipzap
1 Zipzap SE
1 Precious Clone
