Old 09-26-2002, 09:47 PM
Def Def is offline
How do I get access to the PCB?
I'm a newbie to the "scene." was wondering how do I go about opening up the clear cover to get access to the pcb?
Old 09-26-2002, 10:02 PM
Chris's Avatar
Chris Chris is offline
Send a message via AIM to Chris
you slide the clear tab above the pcb to the rear of the car. don't pull up on it or else it will break. don't mess around with the pcb if you are a newbie, though. its really easy to screw something up
when you've tried everything and you still lose, there is only one answer, NOS
Old 09-26-2002, 11:40 PM
cowfish_29's Avatar
yellow fish forever!
its actually not a big deal, just be gentle and note that there are wires as thin as strands of hair under the pcb board that are prone to breakage.
Old 09-27-2002, 02:10 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
mwhah i broke the tabs that are on the cover.....now i have to tape mine down
Old 09-27-2002, 03:31 PM
Chris's Avatar
ouch that sucks
PCB Not working (Strange Dual battery symptoms) kenny_dilger Bit Char-G / MicroSizers 0 12-16-2002 11:59 PM
Another Sucessful PCB Transplant marc515192 Bit Char-G / MicroSizers 6 10-27-2002 10:22 PM
Another Sucessful PCB Transplant! marc515192 ZipZaps 0 10-27-2002 04:37 PM
Zipzap motor and PCB dtmracer ZipZaps 4 10-17-2002 06:01 PM
