Old 07-24-2003, 11:40 PM
ZipRC's Avatar
ZipRC ZipRC is offline
Modder-Eater
Zip problems
I was playign around w/ extra batts, and i made a dual (not laymans). then when i took it out of the car and put in a single cell, the car would only move or work when it was on the charging base of the remote. help?
Old 07-25-2003, 09:07 AM
Labmonkey's Avatar
Labmonkey Labmonkey is offline
Tortured Primate
did you check your antenna? maybe you damaged the solder connection or the wire itself and it isn't making contact.
just a thought
Imagination is more important than knowledge...
Albert Einstein
Old 07-25-2003, 12:17 PM
crweedon crweedon is offline
there's probably a short somewhere, you know that whole path of least resistance crap, anyway go through and check the wiring and the pcb for a short.. hope you have a multimeter, goodluck
Old 07-25-2003, 02:36 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
If it works on the charger than I would suspect that the battery you put in is bad or isn't making contact with the battery terminals. See, when it's on the charger, the terminals are connected directly to the charger contacts. When you remove it, it is running off the internal battery and therefore is dependant on the battery being good and having a good connection. Id check the battery and the contacts the battery touches.
Old 07-26-2003, 02:00 PM
marc515192's Avatar
marc515192 marc515192 is offline
ZipZap Maniac
Send a message via Yahoo to marc515192
Re: Zip Problems
At first tought would be a bad or weak battery, however most often its the contacts. Had a similar problem.
1999 Super Modified Zinc Yellow SVT Mustang ZZ
Bit PCB MOD
It's a sleeper! hehehehe
M/S Mitsubishi EVO Lancer w/modified clone motor
M/S Nissan Skyline
M/S Honda S2000
Old 07-26-2003, 02:13 PM
Azimov's Avatar
Yup, I'd put my money on the contacts. They probably got spread apart or moved when the dual cell mod was done.
Please Help Problems With Zip Zaps Performance And Booster Kit thtlr ZipZaps SE 1 09-25-2007 10:35 PM
Zip Zap SE FAQ Bad Company Tips, Mods and Reviews 4 11-16-2006 08:21 AM
Panther Chariot Zip clone Azimov ZipZaps 12 08-24-2004 09:16 PM
my modded zip vs. all my other cars natedogg4674 ZipZaps 0 11-04-2002 05:32 PM
swapped pcb into my zip natedogg4674 Bit Char-G / MicroSizers 4 10-16-2002 01:53 PM
