Old 07-20-2003, 02:57 PM
civic freak's Avatar
civic freak civic freak is offline
Tiny RC Guru
nonpermanence???? (not permanent)
i know my thingie says im a guru but im not, anyway, i really need some help i want to make a rugrunner 4 next weeks show but i dont know how to make one without making the front wheels permanent can i plese get some help. what i mean is can i do it without using rear wheels on tha knuckles 4 clearence could i use rims and glue it to those please help. Asimov u seam very very smart if u read this and it seems confusing can u interpret it 4 everybody else (not to suck up)
please post
Old 07-20-2003, 03:50 PM
Jtskty Jtskty is offline
Master Debater
Send a message via AIM to Jtskty
I have made a rug runner and can tell you the only way I can see it being non permanent is if when your done you just break the rims off the knuckles.
Old 07-20-2003, 03:52 PM
Tiny RC Guru
can u explain that a little better, im confused
Old 07-21-2003, 01:09 AM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
I think I see what you mean. You want to attach the bigger wheels to the hubcaps of a Zip so you can pop em on and off when you like. This may be possible. You would still need to use Zip tires to hold the hubcaps on, but they would be hidden behind the bigger wheels. Heck, try it. Take some Stomper wheels or something similar and shave any protrutions off the back. Pick a flattish kind of hubcap, like the gold ones (there is a similar silver one like these too) and super glue the back of the bigger wheel to the front of the hubcap. Let it dry really good before you stick it onto the Zip rim. Put a tire on the rim, and squeeze the wheel with a hubcap onto the rim as you work the tire onto the hubcap to hold it in place. You will have to put the tire on first as you won't be able to stretch it over the bigger tires once you have them in place and the hubcap is seated in the Zip rim. I'm not sure if this will hold the bigger tire on, especially when you turn. But if the hubcaps fit nice and tight and the tire is in place well to hold it there, it just might work. The best rugrunner I have made to date is made out of one of the AwesomeRC cars. I put Zip wheels all around and a MW gearbox on the back and it is just unreal in how well it can handle rough terrain. This isn't the red one. It's a different one that I haven't posted yet. Stupid scanner. I've found Zips have some trouble with turning big tires on the front. But, a dual cell mod can make that steering much snappier . You could try something sticky to help hold the hubcap in place too. Like poster gum or maybe double sided tape cut to fit with the holes cut out to accept the pins of the hubcap.
Old 07-21-2003, 02:04 AM
cyberkidd007
well lets see uhm you could take ZZ rims of hotglue lego rims onto it then hot glue ZZ rims to the lego wheels put your tire on and smash and bash or just look okay
Old 07-21-2003, 05:38 PM
Tiny RC Guru
THANK YOU, THANK YOU,THANK YOU !!!!!!!!!!! WOW Asimov YOU KNOW EXECTLY WHAT IM TALKIN ABOUT THANX MAN!!!!IVE GOT TONS OF THOSE STOMPERS IVE TRIED AND TRIED TO TAKE THEM OFF AND I CANT CAN YOU EXPLAIN HOW TO DO THAT?AND CAN YOU EXPLAIN HOW TO PUT THEM ON AND CAN YOU EXPLAIN WHAT YOU MEAN BY PROTRUTOINS AND HOW WOULD I MAKE THEM CLEAR THE SIDES
Old 07-21-2003, 06:00 PM
Azimov's Avatar
Taking them off is a matter of pulling really hard .
I think I already went over how to put them on.
Protrusions are anything sticking out the back that doesn't allow the back of the big wheels to be flat so they will accept the hubcaps nice and flush. Clearing the sides is a whole other animal. You'll either need to mod a body by shaving the wheel wells or make one that rides very high on the chassis to allow freedom of movement for the wheels. Use your imagination. Some of this stuff is common sense.
Old 07-21-2003, 06:04 PM
Tiny RC Guru
Unhappy
THANX ALOT MAN THATS A HUGE HELP!!!!!!!!!!!!!!!!
GREAT place to get clones!! Kenkudaki Bit Char-G / MicroSizers 38 02-06-2003 11:46 AM
