07-16-2003, 02:00 AM
Steering Prob Please Help
I just recently got a clone of a bitchar-g ... lxx char-g yellow supra---- it was workin great but then all of a sudden when i tried turnin on low speed it didnt have enuff power to keep goen.... like itd start of fine at first then slow down then stop but it runs fine in fast mode.... anyone know what to do????
07-16-2003, 02:51 AM
ummm, lets see...do you have any mods on the front wheels of the car? check out my thread "steering problems? i have the answer!"
07-16-2003, 03:31 AM
havent modded it at all... and that lil dial on the bottom.... is on the center.... ive checked it and didnt understand.... all my car duz is just turn to the right slightly...
07-16-2003, 03:44 AM
have you undone the steering column and looked at the magneto discs, wires and magnet? the magnet is probably off center.
07-16-2003, 03:45 AM
uh how do i do that
07-16-2003, 03:49 AM
move the chip to the back of the car. there's a little screw in the front. undo it. pull off the clip and i will tell you what to do from there.
07-16-2003, 03:50 AM
that sounds really risky... do you have yahoo or msn... email me at dmoh7@hotmail.com or d_moh7@yahoo.com
07-16-2003, 04:47 AM
yo i emailed you like 10 times wuts the deal?
07-16-2003, 04:48 AM
i dont know my email is f'd up real bad, man!
07-16-2003, 07:31 PM
Camera springs
It is risky if you're not careful. But it's not all that bad. Although I would check the gears in the back first. If the back wheel axle is loose, then it probably creates alot of friction when it's turning, which creates drag. I don't mean loose like it comes out easy, I mean loose like it slides left and right easy. If so take the back wheels off, grab a small hammer or other useable object and gently bang the wheels closer to each other.
Opening the inside of the steering box is more for unequal steering problems.
07-16-2003, 07:53 PM
thanx alot i think that might be the problem cuz my wheels are kinna loose when its off the floor it duz slip about 2 mm's to the side maybe... how do i take the gears out?
07-16-2003, 07:56 PM
the rear axle *** how do you take it out
07-16-2003, 10:15 PM
Camera springs
Well, this part is highly technical! pull it.
Sorry, not making fun of you. Take your thumb and your forefinger. With your thumb on one wheel and your forefinger on the other, pull. Be carefull not to bend the axle too much.
07-17-2003, 05:22 AM
you also might want to see if you can fit something about a half-a-millimeter-thick piece ofplastic or something in there.
07-17-2003, 12:21 PM
i got it out!! i was hesitant lol... but it got out and i hammerd at it... and it got shorter and i put it in... no more side to side, but the car still goes to the right a bit.
