07-10-2003, 09:24 AM
Title? Whats that?
Hmm... Easier effective dual cell? Could be!
Check this: http://www.zipzaps.com/zzTips.asp go to Add Run time to your Zip-Zap I'm thinking of doing that but wired for speed. Do you think it will work good? And also I'm scared to flip the PCB any tips on the internal? If it works it will be my first dual cell  .
<---Signature Begin--->
Go away!
<---Signature End---->
My XMod:
Black Civic:
-Broken, parts in the mail.
07-10-2003, 02:13 PM
nope it won't work. They forgot to post how to charge it properly  and second of all it won't extend the runtime, only puts out more voltage
07-10-2003, 05:02 PM
Title? Whats that?
So how do you charge it properly?
Go away!
My XMod:
Black Civic:
07-10-2003, 05:18 PM
XMOD AUDI TT (my wish)
if u wire them in parallel then u can charge it easily by chargin the car 3-4 times before running it. But if u wire them in series u gotta deliver more voltage to the batts so ud have to make a custom charger with 3-4 aa or aaa batts.
07-10-2003, 06:38 PM
tiny rc racer
so you're saying if you want it faster wire them in series?
"If I had a bike it would have mad pedals"
07-10-2003, 08:04 PM
Title? Whats that?
No for more speed you gotta wire them paralell I'm gonna try this mod tommarow and Ill tell yall how it works!
Go away!
My XMod:
Black Civic:
07-11-2003, 08:18 AM
I hope you're kidding with us, because if you're saying that for real, prepare to be disappointed.
Wiring batteries in series puts out more voltage. Wiring them in parallel gives you more battery capacity. So, More power getting put out means increasing the juice delivered to the motor rpm , and putting out more mah means more time before the motor stops.
07-11-2003, 10:33 AM
Title? Whats that?
Okay I'm confused now lol. So if I wire them Negative to Postive and Postive to Negetive it will give me more power? But thats exactly what they did and they claim it gives more runtime. And if I wire the + to + and - to - it gives me more runtime? As soon as i figure this out Ill do it. Lol its ur fault im confused charlie!
Go away!
My XMod:
Black Civic:
07-11-2003, 01:29 PM
Oh good grief!!!! You take the battery inside the car, tape one end of the foil to it's negative side and tape the other end to the positive end of the other battery. Then tape a foil strip to the negative side of the 2nd battery and tape the other end.....hang on I'll post a pic.  The gray shaded area is the foil and the black area is the tape
07-11-2003, 03:03 PM
here i think this will help. (i hope)
and for the charger, go buy a 4 aaa batt holder and stick a chargin pod thingy on it. Charge ur duall cell for about 1 minute. Thats only if u choose to do series wiring tho. If u do parallel wiring u dont need a new charger, u just gotta charge it 3-4 times over and over to get the batts full.
07-11-2003, 03:48 PM
Title? Whats that?
Is a duel cell wired in series usless without a special charger?
Go away!
My XMod:
Black Civic:
07-11-2003, 10:19 PM
Anime RPG Nut
Is there a link to a guide that shows how to do a dual cell and controller mod for the purpose of providing more voltage?
07-12-2003, 06:42 AM
Guys, try doing a Google search for series and parallel wiring.
There are TONS of basic electronics sites where you can learn how this stuff works for real.
07-20-2003, 03:58 PM
Modder-Eater
is zipzap antennae wire conductive with the batteries? Because i don't wanna buy any copper and i have like 12 ZZ/Clone antennaes lying around that i could cut the insulation off the ends.
07-20-2003, 04:41 PM
You'd have to solder (or shrink wrap) the wires to the batts. but it should work.
Or you could try the Layman's Dual/Tri Cell mods. Somebody is even working on a Layman's Quad Cell right now!!!
Layman's battery mods are GREAT for performance. They weigh pretty much the same, if not less, and that doesn't affect the weight of your car. So, you would have more power.
