01-13-2003, 10:38 AM
Mini-Z Wheels...
Do Mini-Z wheels fit the Mini-X car...
Look here, nice alloy wheels...
HaCo
04-07-2003, 05:31 PM
Z Wheels
Haco,
I own a few Mini-Z's, 7 to be exact.
Unfortunately the Mini-Z wheels do not fit the Mini-X.
I have looked into perhaps modifying them to fit, but it is too much work and the Mini-Z has a smaller diameter axle too, it is too bad they don't fit, as the Mini-Z wheels are available in 9mm wide (same as Mini-X) and 11mm wide.
The Mini-X's wheels are crap and the tires even worse.
Second place is first loser...
04-10-2003, 06:45 AM
Is it possible /feasible to modify the Mini-x axles to take Z wheels??
(custom parts maybe, tinyrc??)
04-10-2003, 08:09 AM
Re: Z Wheels
Kid_Cojonez,
That sums in up...
04-15-2003, 07:49 AM
I shall call him Mini-Me
wut if u have acsses to a machine shop?
future car: white 1966 Pontiac GTO
05-11-2003, 11:06 PM
Mini-Z tires do fit the Mini-X wheels (At least the foams do).
05-12-2003, 06:26 AM
Got Cheese?
the two wheels aren't even close, I've looked into it myself. mondo's right!
05-13-2003, 12:48 AM
You can make Mini Z wheels fit with only a small amount of work.
First, when using mini z wheels the wheel track will be widened by approximately .30" so you will need a much wider body or you'll have to do some customizing to your current body.
Second, you will need 4 plastic axle bushings (if you added real bearings to your kit you should already have these laying around). In each bushing cut a groove through the center of one side just wide enough to fit over the pin that goes through the center of your axle. Now insert and glue that bushing into the back of the mini z wheel where their bearing is supposed to go (leave out the outside mini z bearing). It's that simple, you now have a mini z wheel that can be bolted onto your mini x.
One final note, you will have to turn your wheel nuts around backwards so that the nylon portion goes on the axle first in order for them to fit on the mini z wheel. As the nut is tightened down onto the mini z wheel it will center the wheel onto your axle shaft.
One more thing. Remember: If an individual says something can't be done, it just means it can't be done by that individual - Michael Strother
05-13-2003, 02:59 AM
Now Why didn't I think of that???
05-13-2003, 10:26 PM
mini-eX-Driver
simply savage
so simple, so savage!
soon to be
mini cooperS (bmw) mini-x
novak xxl receiver
lrp quantum micro esc
hpi micro mod
5 2/3a zapped cells
novak 10v 4700u power cap
xmod suspension
xmod wheels and tire upgrade
