Old 11-28-2002, 01:04 AM
Kingofjapan's Avatar
Kingofjapan Kingofjapan is offline
Don't you hate pants?
GO BALL BEARING...solution to those pesky axel problems
hey guys, when I was thinking of making my pan chassis, i came across some kick a$$ micro ball bearings that could potentially replace those stupid loose axels on clones and such. These bearings come in a 1mm inner diameter which is perfect for the bit charge axels. all you would have to do is cut out a small circle and glue the bearing place. tadah, you will never have to worry about loose axel again.
i will post results when i get them from the NTN bearing corp of Canada. here is what they look like if you have no idea what i am talking about..
"Till all are one"
-Optimus Prime
Old 11-28-2002, 01:10 AM
Acceptable_Risk Acceptable_Risk is offline
Just one question:
How would you get your axle on there?
Old 11-28-2002, 01:13 AM
pull one end off...
you pull one end off of the axel and thread it thru the two bearings, then super glue the wheel back on to the axle. or even better you could cut the axel in half and link the two ends with a small peice of tubing that would grip it tightly.
then you could take it out if you needed to clean the bearings with out needing to reglue the wheel.
"Till all are one"
-Optimus Prime
Old 11-28-2002, 01:45 AM
Clint Clint is offline
Wide Open Throttle
Re: pull one end off...
hmm...my axle is on it's way out..
i can smell an independant rear suspension or a rear diff setup soon.
Old 11-28-2002, 09:18 AM
here's what you need to do..
indenpendant rear suspension...take a look
"Till all are one"
-Optimus Prime
Old 04-24-2003, 01:38 AM
micro_Amps's Avatar
micro_Amps micro_Amps is offline
Or you could use a loose axel clip like this......
Loose axel clip link
uA
Old 04-24-2003, 12:49 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
bearings would rule. i didnt think they made them small enough for bits. gimme info on price and stuff. this would be the ultimate if they are small enough.
Old 04-24-2003, 11:04 PM
bdebde's Avatar
bdebde bdebde is offline
That's all folks
I think that 1mm is too small for the axle. I have found some bearings for this also. They are .047 (size R0) which is like 1.19mm. Hope you didn't order them yet.
That's all folks!
Old 04-30-2003, 05:56 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
where can you order these small ball bearings?
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 04-30-2003, 09:49 PM
NewZZaddict NewZZaddict is offline
Where to buy bearings
I found this bearing site that has some that should work. Scroll down to "Inch Miniature Bearing sizes" or "metric miniature 1mm to 9mm bore". bdebde, was that .047 the size of the bearings you found or did you measure the axle? I lost my micrometer
http://www.bocabearings.com/prod_map....cfm?showall=y
They're not cheap but if you buy 25 or more you get 20% off.
Old 04-30-2003, 10:04 PM
TypeZer0's Avatar
0reZepyT
wow, it's like 10 bucks per ball bearing on average on that page.
Old 04-30-2003, 10:18 PM
bdebde's Avatar
That's all folks
Yeah I measured the axle. The bearing size is R0 or 3/64 (.047).
Here are a couple others:
http://www.consbrgs.com/
https://sdp-si.com/eStore/
Yeah the price is pretty steep, that is why I have been putting off buying any. After I get a couple other projects done, I will have to get some.
That's all folks!
Old 05-01-2003, 12:48 PM
TypeZer0's Avatar
0reZepyT
that second link has some other interesting stuff like clutches and universal joints and some of them seem pretty small too....i can imagine a 2+speed transmission and front and rear independent suspenions and all wheel drive in a chassis that still fits on the palm of your hand excuse me while i grab a couple of towels to wipe this drool off myself
Old 05-01-2003, 09:32 PM
bdebde's Avatar
That's all folks
Originally posted by TypeZer0
...excuse me while i grab a couple of towels to wipe this drool off myself
No doubt!
That's all folks!
Old 05-02-2003, 08:37 AM
crazydave's Avatar
Garage Rocker
Man, those bearings really aren't cheap. I'd like to get some bearings but I'm having a hard time rationalizing the cost. I wonder if the speed gain would even be that significant. I know bearing made a big time difference in my 1/10 scale cars, but I was replacing 16 bushings with 16 bearings, in a 5 lb. car, but how big of a difference could 2 axle bearings make in such a small car? And what about the front wheels, bearings there could also be beneficial, but bearings on all four wheels would be getting insanely expensive for a $20 RC.
So I'm wondering, just how am I going to rationalize this to myself, because I want to do it.
xmod ball bearing used to make ball bearing motor!!!!!!!! rydzjunior XMODS Mods and Projects 2 07-18-2007 09:41 PM
Solution for some with steering problems. jayd177 Combat Digi Q 0 12-18-2002 11:19 AM
