Old 04-24-2003, 10:43 AM
350z-zz 350z-zz is offline
problem
i have a 350z zip zap and whenever i go backwards it keeps spinning in circles, ive check for malfunctions under the pcb but cant find to solve the problem. i might go to RS if i cant fix it myself but id rather know what im doing for the future. lately it starts spinning when i go fowards also. ive changed, gears, motors and wheels back to stock and same problem.
any suggestions are welcome and thnx for ur time
Jim
Old 04-24-2003, 10:58 AM
NatakuARN's Avatar
NatakuARN NatakuARN is offline
Anime RPG Nut
Did you try adjusting the little switch in between the front wheels?
Old 04-24-2003, 11:06 AM
yea the turning is much steeper than a simple adjustment will make, btw it usually rides straight going fowards, just going backwards it starts spinning like a maniac
Old 04-24-2003, 01:29 PM
Clint Clint is offline
Wide Open Throttle
it means the steering spring is too loose and cant hold the wheels straight...
u can either make your own out of thin wire..(search..there's a diy steering spring twisty wire howto thread)
or double up using another steering spring.(this works very well)
Old 04-24-2003, 06:10 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Sounds like you got a bad one. As stated, either the steering spring is loose or the PCB has a problem crossing the reverse circuit with the steering coils. Seems that if the spring were to blame, you'd get the same problem in forward as well. But, there may be a difference in the friction variable on the front wheels in either forward or reverse, so it could still be the spring. I'd take it back in either case.
Old 04-25-2003, 05:20 PM
charliebrown's Avatar
you could try doing a rare earth magnet upgrade from rcmod.com
Old 04-25-2003, 05:39 PM
WAIT A MINUTE!!!!!!!!!!
Since when am I a "pro"?
sputtering problem with my new zap... Cool Dad ZipZaps 12 06-20-2003 11:05 PM
Dogbones popping out? No problem. bluemax_1 Mini-X 3 04-01-2003 10:39 PM
Transmitter problem (picture included) ryanhook Bit Char-G / MicroSizers 11 12-26-2002 08:29 PM
Charger clip on PT Cruiser problem Jonny B ZipZaps 4 10-18-2002 03:57 AM
AH-HA!!! Solved uneven steering problem! mechanist ZipZaps 8 10-17-2002 09:24 PM
