Old 09-14-2002, 11:07 PM
retroicon retroicon is offline
Painting Tips.. Anyone?
Hello,
I got a few clear bodies but I noticed they don't have anything on the inside to block the windows during painting.... have you all been spending hours trimming tape by hand to do the windows?
Icon.
Old 09-15-2002, 01:40 AM
Shacky Shacky is offline
I haven't painted my bit yet, but if you're painting the outside, just cover the clear areas from the inside. Don't worry about being exact since you are just making sure that stray paint doesn't get in the clear areas.
Clear areas include the windows, head lights, and tail lights.
Old 09-15-2002, 02:02 AM
Well.. i'm not exactly painting :-) ....
I just decided to pull out the blue painters tape and work with an exacto knife from the inside.... I just hope it looks as cool as I think it will when I'm done... if not I've wasted a few hours :-(
Icon
Old 09-15-2002, 12:55 PM
ckw01hk ckw01hk is offline
Send a message via ICQ to ckw01hk
of course u need to mask the clear window on both outside and inside area. put on the tape and use tiny razor to cut along the planel lines on the outside to get the shape and just stick on big tape in the inside. .
Custom R34 to R32 skyline
Custom GT one
Old 09-15-2002, 06:10 PM
I'm painting a clear body FROM THE INSIDE ... I'm not painting the outside..
icon
Old 09-15-2002, 11:23 PM
well, u need to mask the window only.
u can try following and cutting the shape from the outside and then use it in the inside.
Custom GT one
Old 09-17-2002, 06:10 PM
DrkRAM DrkRAM is offline
I've painted my bodies from the outside. But try Liquid Mask, you should be able to find it at any local hobby store.
You just paint it on with a brush, about 2-3 coats. Let it dry, then paint your car and when your done peel it off the windows.
Huh?
Old 09-17-2002, 06:39 PM
kwikbb's Avatar
kwikbb kwikbb is offline
smoove operator
yeah liquid mask rocks... it's great for headlights and turn signals ect. all the small things.
Old 10-08-2002, 02:07 AM
henry's Avatar
henry henry is offline
13B REW
u could also use elmers school glue as liquid mask and cost less$$ its good i used it on my accord wagon.
Old 10-09-2002, 03:15 AM
NorCalCoug's Avatar
NorCalCoug NorCalCoug is offline
l33t camber wizard :)
If you're spraypainting, you can also use vaseline applied to the surface that you don't want painted. You just have to be careful not to peel your fresh paint off when you remove the vaseline.
Old 10-09-2002, 07:54 PM
d00kie's Avatar
d00kie d00kie is offline
It's super useless!
To be on the safe side, use modelling masking tape, works best. Paint will rarely bleed through it. Also, theres this special masking tape I got called parafilm. It stretches and wraps the area you want nicely. http://micromark.com
Old 10-09-2002, 09:24 PM
ndto ndto is offline
takumis nightmare
Send a message via ICQ to ndto
you can you scotch tape too lol , i just finished using it on my celica and i think it works really well and its cheap
Painting a ZZ rody ZipZaps 3 11-07-2006 09:51 PM
questions about painting gorbasho XMODS Parts and Hop-Ups 7 04-12-2005 08:20 PM
Painting the body Rumiko12345 XMODS 1 02-23-2004 08:42 AM
Painting Tips Mclaren XMODS 0 11-24-2003 09:42 AM
