Old 04-10-2003, 06:48 PM
dr1zz's Avatar
dr1zz dr1zz is offline
phear meh..............
Question dual/dual cell?!?
if i had 4 batts.........2 in series w/2 parrallel to the series batts....2.4v?
could i charge with 3v?
Old 04-10-2003, 08:25 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
yes, i charge all my dual cells with 3 volts, like namuna sed, not necessary to go much higher than the voltage rating of the battery pack. btw, since you have 2 more in parallel with the first two, it'll take you twice as long to charge
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 04-11-2003, 02:50 PM
Duratrax Duratrax is offline
Send a message via ICQ to Duratrax
How do i charge my 2 cell bit?
**** can happen
Old 04-11-2003, 03:04 PM
TypeZer0's Avatar
0reZepyT
i'm guessing you didn't read my reply....
Old 04-11-2003, 03:49 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
no you cant effectivly charge 2.4v with 3v.
4.5 will.
the easiest way is to get a single aa holder from radioshack. its a dollar and its easy to install.
Old 04-11-2003, 04:47 PM
TypeZer0's Avatar
0reZepyT
that's what i used to think but on my dual cells, i don't notice a difference when i charge at 3 volts or 4.5 volts or 6 volts other than how fast the battery in the car heats up
Old 04-11-2003, 05:05 PM
hogjowlz's Avatar
as soon as it starts to heat up it is done charging.
Old 04-11-2003, 05:28 PM
TypeZer0's Avatar
0reZepyT
i usually charge about 3 minutes if i have 150 mah cells, 1 minute if i have 50mah cells
Old 04-11-2003, 05:53 PM
dr1zz's Avatar
thx TypeZer0
Tri cell mod. RobotGT Tips, Mods and Reviews 1 02-24-2010 04:27 AM
Tri cell mod RobotGT Bit Char-G Mods and Projects 5 09-25-2003 04:22 PM
which dual cell should i do, laymans, external, internal etc eman1 Bit Char-G / MicroSizers 11 09-02-2003 07:42 PM
Tri cell mod RobotGT Bit Char-G / MicroSizers 3 07-27-2003 11:06 AM
