04-10-2003, 06:48 PM
phear meh..............
dual/dual cell?!?
if i had 4 batts.........2 in series w/2 parrallel to the series batts....2.4v?
could i charge with 3v?
04-10-2003, 08:25 PM
0reZepyT
yes, i charge all my dual cells with 3 volts, like namuna sed, not necessary to go much higher than the voltage rating of the battery pack. btw, since you have 2 more in parallel with the first two, it'll take you twice as long to charge
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
04-11-2003, 02:50 PM
How do i charge my 2 cell bit?
**** can happen
04-11-2003, 03:04 PM
0reZepyT
i'm guessing you didn't read my reply....
04-11-2003, 03:49 PM
no you cant effectivly charge 2.4v with 3v.
4.5 will.
the easiest way is to get a single aa holder from radioshack. its a dollar and its easy to install.
04-11-2003, 04:47 PM
0reZepyT
that's what i used to think but on my dual cells, i don't notice a difference when i charge at 3 volts or 4.5 volts or 6 volts other than how fast the battery in the car heats up
04-11-2003, 05:05 PM
as soon as it starts to heat up it is done charging.
04-11-2003, 05:28 PM
0reZepyT
i usually charge about 3 minutes if i have 150 mah cells, 1 minute if i have 50mah cells
04-11-2003, 05:53 PM
thx TypeZer0
