Old 03-25-2003, 04:00 PM
Racer9's Avatar
Racer9 Racer9 is offline
Tiny RC Pro
Motor Cleaning tips
5 tips to help you keep your motor running like new!
1. MOST IMPORTANT!!! When you buy a new motor break it in by running a few charges through it then drive carefully for two more charges then let it rip!
2. Clean off shaft by the gear. (take gear off then use tweezers to pull off dirt)
3. Lube the ends of the motor sparingly using WD40 or oil. You can also use dry lubrication. (Wipe up after yourself!)
4. Try not to switch directions of the motor quickly or constantly.
5. Don't overload the motor.
Have fun use motors that run like new!
Old 03-25-2003, 04:15 PM
SlowbutCourious's Avatar
State Property
...i would not recomend usin any oil or lub on theise motors..i have done that with 3 motors and now none work right..oil keeps dirt in your motor un less u can take it apart 2 clean the inside i would not do it !..i tried wd40/ high quality gun oil / and gun sheath (displaces dirt and moisture ) no luck here ...*edit*are u close to steubenville OH ?
Old 03-25-2003, 04:27 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Retarded Stunt Driver
Re: Motor Cleaning tips
i break almost all of those rules and my motors still scream. a few have almost daily usage for about 6months.
Old 03-25-2003, 04:34 PM
Racer9's Avatar
Tiny RC Pro
but they will suddenly die trust me!
Old 03-25-2003, 04:37 PM
hogjowlz's Avatar
after about another 1000 hours of use maybe. i will have goten my 4$ worth by then.
Old 03-25-2003, 04:40 PM
Web Guy's Avatar
Web Guy Web Guy is offline
Internet Web Ninja
I am with you on this one hogjowlz....
What no sudden forward to reverse or wheelies or anything? Geeez what fun are you having with your cars? Clean and ad oil all of the time? Geeez just run the $5.00 motors into the ground then buy a few more.
Old 03-25-2003, 04:43 PM
Racer9's Avatar
Tiny RC Pro
I mean like run in reverse for a while and slam it forwards. All motor experts don't recommend sudden direction changes. I didn't break in my 3.0 and now it is slower. I still haven't done the WD40 yet but it worked fine on my 1.0!
Old 03-25-2003, 04:45 PM
hogjowlz's Avatar
ive yet to have a good motor fail on me. ive had a few that had issues from the start. but none that developed problems down the road.
my "pink clone motor" has put 5 or 10 cars to their grave and it still runs strong.
Old 03-25-2003, 04:49 PM
Racer9's Avatar
Tiny RC Pro
Hey its reccomended by RCCA so trust me on this one! It will slightly decrease the motor by doing that but it is still going to die. This is mainly for people that run r-spec and other high performance motors in dual and triple cell cars. If you run quad cell expect your motor to die all of a sudden!
Web Guy's Avatar
Internet Web Ninja
I have only had one bad motor and it came bad when I received it. All of my 3.8's, 3.0's and 2.6's still run like the day I received them.
Old 03-25-2003, 04:51 PM
hogjowlz's Avatar
what is rcca? ask any mechanical or electrical engineer about this and they will chuckle at you.
4.8v is higher than recommended voltage for that motor so ya it will probably develop problems.
do you run 4.8v to your pod racer?
Racer9's Avatar
Tiny RC Pro
did you break them in?
Old 03-25-2003, 04:52 PM
Racer9's Avatar
Tiny RC Pro
I will probably try to make a motor with ball bearings in the ends and in the axle, too!
Old 03-25-2003, 04:53 PM
Web Guy's Avatar
Internet Web Ninja
I break them in a little by just setting them on the charger and running it for about 1 minute. And then in the car the go and that's it!
Old 03-25-2003, 04:54 PM
State Property
...i think its all in the construction of the motor how long it lasts... takin it easy on the motor is not goin to in crease life if its time 4 your motor 2 go its gone!..
radioshack racing series tips 10_second_supra XMODS 24 02-22-2004 11:32 PM
traction tips aero528 XMODS 19 11-20-2003 08:25 PM
place ur tips here!! lanevo7 Bit Char-G / MicroSizers 18 10-22-2002 05:31 PM
