02-23-2003, 06:37 PM
Sir Wrench a Lot
Sounds cool Steve,
But........ Let me play the devils advocate
1. Different body sizes and chassie types can change the charge contact points by as much 1/4" which is a lot when your trying to hit a point thats about 3/16" square.
2. Your track would have to on a table or you need a elevated section to make it work.
I was trying to make this as easy as I could with little or no cost and portable also.
I know if you make your idea work there will some "Gear Heads" in here that will make them also my self included. But for right now i'm trying the 'KISS" principle (Keep It Simple Stupid)
PT Curiser, Honda Civic ,Porsche 911, Mustang (ZZs)
Honda S2000 MicroSizer
2 Old Motor Works 1 Style
2 Rally Racers
1 Cannonball Racer
1 Nakamichi N Racer
1 Micro RC (w/pistol grip remote)
If you can't fix it get a bigger hammer!!!
40 years old and still a kid (except I can drink beer)
02-23-2003, 06:48 PM
zipped up tight!
Originally posted by Dutch
Sounds cool Steve,
Yep, thought of all those but thanks for pointing them all out again! LOL. Fortunately for me, my track is elevated, and it's about 2 inches thick which would give plenty of mounting depth. But since most tracks aren't, there's got to be another solution.
A small platform idea wouldn't be bad as you could build it up on a sheet of Lexan, then just move it around wherever you want...the Lexan edges can be sanded paper thin so the cars can drive onto them with ease.
The body type wouldn't matter as the blocker could be below the from bumber, just high enough to halt the front wheels, it doesn't take much to stop a coasting Zip. This way, the wheelbase is what I'd use for measurement purposes.
Glad to see someone is still interested in this at least a little. Any idea where I might find a micro solenoid?
02-23-2003, 07:28 PM
Sir Wrench a Lot
Steve,
Funny you should ask. I have a solenoid in my junk box that I ripped out of a 240 meg Sy-quest drive but it's kinda big
1-1/2" lg x 3/8" dia
2 Rally Racers
1 Cannonball Racer
1 Nakamichi N Racer
02-23-2003, 07:34 PM
zipped up tight!
oooh!
do it do it do it!!!! Make it HUGE right now...then make it practical. You got me thinking, CDROMS have mechanisms that move up and down to clamp the disc..they're geared, but they might work. I'll look into it.
02-23-2003, 07:36 PM
zipped up tight!
Steve,
LOL, I can see it now...the Zip drives over it, you flip the switch and POW..the solenoid launches the Zip sky high...hehehe
02-23-2003, 08:04 PM
Sir Wrench a Lot
Steve,
I ripped apart a CD also, 2 motors no solenoid :-(
Where I work is getting rid of a bunch of old computer stuff and I told the IT guy to give it to me be he trashed it. So far 2 CD rom's
2 3-1/2 floppys 1 sy-quest 1 Jazz drive 2 old 233 computers and a bunch of odd's and end's
2 Rally Racers
1 Cannonball Racer
1 Nakamichi N Racer
02-23-2003, 11:36 PM
zipped up tight!
Steve,
I ripped apart a CD also, 2 motors no solenoid :-( ...
...silly me, the front end of a Zip (or clone) is exactly what I need. I've got a few parts cars laying around, I'll see what I can find.
02-24-2003, 10:11 AM
Clones Are Good
Returning to a simpler idea:
A small bent plate (very small - a piece of card stock may work) slightly bent so that when a bit or zip backs onto it, the weight of the rear wheels rocks it backward, lifting the charging contacts (like slot car pick-up shoes) into the charging points on the bit. It could be very small and very simple. The weight of the bit would lever the charging contacts into place. Then when you want to leave, you just mash the go pedal.
The scale of the drawing is very wrong, as I had to just throw it together as a concept drawing. Very light wire could be used to power the contacts, which could be left on. No energy would be lost unless they were shorted, or if a car pulled up to charge.
02-24-2003, 06:39 PM
zipped up tight!
nice!
you might be on to something here. Might I suggest using ribbon cable from old CDROMs or Laptops to run to the charging terminals..it's so thin you'd never know it was there.
02-24-2003, 06:58 PM
Quack
wow, i like your idea you have BenCloned! it's simple, but looks like it could work!
02-24-2003, 09:55 PM
.002 sec away from $100!!
I saw a track with metal that you drive on and it autmaticly char-ges the car
02-25-2003, 04:52 PM
Quack
do you have any pics or a website or something sm2osley?
03-04-2003, 10:38 PM
look. You can drive in & back out when finished. Pic is a cut-away of the front of a car
Keep It Simple Stinky!
03-12-2003, 07:25 PM
Quack
where is the other wire to make contact? if you only stick one wire out, your not going to be going very far.
03-12-2003, 07:58 PM
XMOD AUDI TT (my wish)
okidoki
heres my idea
u put 2 new charge contacts in the rear end of the car right under the motor/gears
then in ur charge station u have 2 lil springs popping out and
2 toothpicks placed so the rear wheels can fit right in.
you drive in and you go right into the toothpics, then the springs
hit the new charge contacts and viola.
