Go Back   TinyRC.com > 1/64 and Smaller > Digi Q > Combat Digi Q
Old 02-22-2003, 08:27 PM
Meltdown's Avatar
Meltdown Meltdown is offline
Gun sound mod!!!
I got my T34 and Panther last week. I already made a mod. Using a voicemail greeting card.
I wanted to add a gun blast while firing... so i did
You'll be able to record your own gun sound with this and trigger it with the controller.
Works perfectly! Adds a lot of exitement to the battle
(disclaimer)
If you try to do this you will need some electronics experience. Don't blame me if you fry the controller.
Old 02-22-2003, 08:42 PM
Meltdown's Avatar
Opening the greeting card.
Old 02-22-2003, 08:49 PM
Meltdown's Avatar
Plenty of room in the controller
Old 02-22-2003, 08:50 PM
Meltdown's Avatar
Okay i get it now
Old 02-22-2003, 08:52 PM
Meltdown's Avatar
Used a 6 volt relay to seperate the sound pcb signal and the trigger signal.
The (right) trigger must be removed of the controller and connected to the + side of the battery
and the + of the relay.
The switch contacts of the relay are connected where the trigger connections used to be.
The other contacts of the relay are used to trigger the sound pcb.
Old 02-22-2003, 08:55 PM
Meltdown's Avatar
Old 02-22-2003, 08:56 PM
Meltdown's Avatar
Old 02-22-2003, 09:00 PM
Meltdown's Avatar
The right trigger is connected via the relay to the sound pcb.
Sqeezing the trigger will play the gun sound and the tank will recoil as normal.
The relay is needid to isolate the sound pcb from the normal trigger signal.
That's it for now. I hope you like it.
Old 02-22-2003, 09:35 PM
jayd177 jayd177 is offline
That is pretty damn cool. It looks like that speaker fits right in there like it was at home or something. That's cool.
Old 02-22-2003, 09:43 PM
Meltdown's Avatar
Thanks, i'm having a blast with it.
Old 02-24-2003, 07:38 AM
Meltdown's Avatar
Just modded my second controller. The nice recording feature allows me to change the
gunblast sound on the second controller.
So you hear wich tanks shoots due to their distinct sound.
Now i will look into adding a gun flare while shooting using a yellow led in the gunbarrel.
Old 02-25-2003, 03:47 PM
Napalm_Guru's Avatar
Napalm_Guru Napalm_Guru is offline
Wanna Drag??
Looks sweet, but im waiting for the "sound pod" that Helix mentioned earlier.
"Going to war without France is like going deer hunting without an accordion. You just leave a lot of useless noisy baggage behind.
-Jed Babbin
Old 02-25-2003, 03:54 PM
Namuna's Avatar
Namuna Namuna is offline
Great stuff Meltdown! Thanks!
Old 02-25-2003, 05:13 PM
Meltdown's Avatar
Just added the gunflare mod.
I will make a new thread for it with scematics and photo's when all is documented.
Old 02-25-2003, 05:20 PM
hyperdriveb
Nice work
Best Mod Contest (UNOFFICIAL) midget_man1387 Bit Char-G Mods and Projects 56 03-17-2003 10:38 PM
