Go Back   TinyRC.com > 1/64 and Smaller > Bit Char-G, MicroSizers, Z-Cars, Clones > Bit Science
Old 02-21-2003, 06:31 AM
fuzzy2cell's Avatar
fuzzy2cell fuzzy2cell is offline
6v battery=NOS!!
damn! Wouldn't a 12v blow the circuit board or something?
working on a
transmission with a
Old 02-21-2003, 08:14 AM
wild03 wild03 is offline
Oh I'm sure! But Im bypassing the board anyways, Is the motor that worries me!
Old 02-21-2003, 03:26 PM
fuzzy2cell's Avatar
6v battery=NOS!!
LOL!!
working on a
transmission with a
Old 02-21-2003, 10:04 PM
johnrtse's Avatar
johnrtse johnrtse is offline
This H-bridge concept has me intrigued. I am building a multi-cell Dragster right now and was planning to do the std. transistor mod, but had some reservations about having the weight of an extra cell in there just to power the pcb (this thing will be plenty heavy enough!).
I'll be watching this post closely, wild!
John
"It takes a Mopar to catch a Mopar!" - Vanishing Point
Old 02-21-2003, 11:29 PM
Project RC's Avatar
Project RC Project RC is offline
RC TUNER
I did exact thing as the diagram describes, but it doesn't work. How do I test it? I don't want to blow my pcb. What is the best way to test the set up without soldering it to the pcb? Help.
Dragster, ,
Rally Car, , custom , , , custom modded chassis, custom body, custom sterring magnents
"Cheap, Fast, Reliable. Pick any two"
Old 02-23-2003, 12:16 AM
I would double check all the connections make sure your transistor is in the correct position. Download the specs by doing a search on "2N2222A" also those that have a metal cap, like the one I used, the cap is actually connected to one of the legs(collector) pin so make sure you don't touch the cap to any of the circuit.
The easiest way to test is to use a 1.5v battery (AA AAA etc.) instead of the PCB. By connecting the battery where the PBC would connect the motor should turn.
Oh I noticed than the colors an the diagram could be a little misleading, the 4.5v battery (+) is connected to the motor and (-) is connected to the transistor and to the negative on the PCB
I recommend testing the circuit this way before putting it on the car.
Old 02-23-2003, 07:44 PM
John
Well, I finally got to do some rough testing and the good news is that the H-bridge actually switches back and forth, the bad news is that the thing is SO inefficient that it doesn't work.
I used a simple 4 transistor H-bridge, a pair of 2n2222a NPN and a pair of 2n2907a PNP. check this page for details.
http://library.solarbotics.net/circu...arHbridge.html
I didn't use inverters or buffers on the input so my bridge is what they call the "Bolt Light" check this page for some data on it
http://library.solarbotics.net/circu...varH_test.html
I used a 1.5v pager motor for the tests. and Power supply Vcc set to 1.506v
Vcc = input voltage
Vnl = Voltage "No Load" (no motor)
Vm = Voltage across motor
Im = Amps at motor.
First I took some measurements with just the motor connected to the power supply.
Vnl = Vcc = 1.506v
Vm = 1.488v
Im = 42mA
Second I used the simple transistor switch from my page, with a 1k resistor at the base. again Vcc = 1.506v and I used a 1.5v AA for the input signal.
Vnl = 1.487v
Vm = 1.28v
Im = 51mA
Third the "Bolt Light" H-bridge Vcc = 1.506v
Vnl = .7v
Vm = .038v
Im = 5.8mA
needless to say that with this numbers the motor didn't move. inverting the input signals did invert the Vnl voltage from +.7v to -.7v so the H-bridge was at least switching. Invreasing Vcc didn't have an effect on Vnl. I don't know why this is so, I'll have to leave it to the experts.
Old 02-27-2003, 05:49 AM
Project RC's Avatar
RC TUNER
I got mine working now, just some soldering point problem, I redo to soldering, now they work.
Dragster, ,
Old 02-27-2003, 09:20 PM
CRUMB's Avatar
CRUMB CRUMB is offline
Send a message via AIM to CRUMB
Talking
two words .....thats......sick!.....
JuDgE nOt LeSt Ye Be JuDgEd YoUrSeLf
Old 04-06-2003, 04:30 PM
bdebde's Avatar
bdebde bdebde is offline
That's all folks
Here is a link to an h-bridge:
H-bridge
It has most in german, some in english, a translator will help. I have not tried this yet, but their results look good.
That's all folks!
Old 05-10-2003, 11:21 AM
charliebrown's Avatar
Ok what it I just put the 3 LR44 's instead of the Nimh nattery and put in a high racing motor, will I still be fast?
Old 05-12-2003, 08:43 AM
Nah! Yu'll probably smoke the board!!
Old 05-23-2003, 08:02 PM
Well, that is why my screenname is charlie brown....I always come up with the lamest ideas...and ugh thinks HE's stupid, look at me!!!
Old 06-30-2003, 02:23 AM
That is one confusing mod. Can you show easier steps on how to do that nitrous system thingy???
Old 07-29-2003, 09:21 PM
I am VERY insulted.....is there a reason no one has replied to this thread in over a MONTH??? DON'T TEST MY PATIENCE!!!! lol ok maybe I was a li'l bit too angry sorry
zipzap and zipzap se? xmod456 ZipZaps 8 01-24-2005 04:11 PM
just went through my parts box....... airbob20 For Sale/Trade 10 01-25-2003 11:21 PM
Zipzap motor and PCB dtmracer ZipZaps 4 10-17-2002 05:01 PM
BitDra-G reg. times for the ZipZap in! QFM Racing QFM Racing Customer Support 2 10-02-2002 01:09 AM
BItDra-G times recorded for 2.4v ZipZap QFM Racing Bit Char-G / MicroSizers 13 10-01-2002 09:15 AM
