Old 02-16-2003, 09:20 AM
Squishy's Avatar
Squishy Squishy is offline
Quack
rally track; how much can a bit handle?
i am making a rally track out of old paper napkin rolls. I dont have a bit yet, because i need to get some cash first, but am board like crap and wanted to do something. i am using thin carboard to make little ramps up the side, like washboards. (whoop-de-doos)
How much can a bit handle?("ralley" wise) i have also made some little jumps and stuff too. I will try to post pics when i get a chance. anyone tried a ralley coarse before with regular bits?
Old 02-16-2003, 10:02 AM
PWalk's Avatar
PWalk PWalk is offline
Where's the Beer?
Send a message via AIM to PWalk
They can only handle an incline of about 15-20 degrees.
I have already built one so check out these pics for inspiration.
By the way it's finished, new pics are coming soon.
and if your going to be using dirt on the track let me recommend
going to a Dollar Store and picking up Cinnamon! It looks the part and smells a hell of alot better than dirt.
I'm taking the Bit's offroad!
Old 02-16-2003, 12:38 PM
Squishy's Avatar
Quack
cool track. lets see the finished pics! and you use regular bits right?
Old 02-16-2003, 01:14 PM
Heat's Avatar
Heat Heat is offline
Zhuge Liang - My Idol
make sure your car has drift axels!
Old 02-16-2003, 01:41 PM
nrmcj's Avatar
nrmcj nrmcj is offline
Rice Me
cinnamon.. good idea! heh, blue axles and 1.6 motors! ^_^
Old 02-16-2003, 02:46 PM
PWalk's Avatar
Where's the Beer?
At first I was using baby powder, but then I thought cinnamon would look alot more like dirt, and so Presto! All you have to do is blow out the bits with a can of compressed air.
I use both regular Bits and I have a booster (Fairlady).
I actually prefer the booster than a regular bit because of all the turns, and secondly when your taking a hill I like to take them unboosted, then when I get stuck I kick in the booster and away you go. Here's another angle.
Old 02-16-2003, 06:33 PM
Squishy's Avatar
Quack
cool, thanks!
Old 02-16-2003, 08:46 PM
Squishy's Avatar
Quack
Heat, how would drift axels help? and pwalk, do you have any vid.s? that would be sweet
Old 02-17-2003, 05:31 PM
KevBit KevBit is offline
Heeyyyy
hi im new.....but not new to bits....I have an idea. Instead of using cinnamin over and over again. Get some 3M and spray all over the area you want to have "dirt" on. Spread out an even amount (or not even for that authentic dirt look) of cinnamin on the track surface. Make sure you have just what you want on the track, maybe even add some paper underneath the cinnamin to create a bumpy texture.
Then after its all how you want it, Get some 3M spray adhesive and spray it alllll over the whole track surface of cinnamin on top. This way you are sure the cinnamin will stay put when you are "rally racing" over it.
If you are not sure you want to do this to your preciuos rally course, cut out an EXACT layout of the track area you want to be "dirty" in paper. Do the same thing to the paper as you would the track, then just layout the paper ontop of the track surface. For it to be secure stick some double sided tape on the bottom of it.
Hope this helps you guys in your rally track building experiments!!! (ps make sure to the body off the chassis before performing serious offroad stunts )
-=45mhz Rx7=-
Old 02-17-2003, 05:33 PM
muhhaahhahha
i will attempt to make a scale version of the PIKES PEAK RACEWAY!!!! AHHAAHAhahahahh haahh ha ah....... . That would be wicked cool with a Lancer Evo Rally bit car sliding around the corners just like on the WRC!!!
-=45mhz Rx7=-
Old 02-17-2003, 07:07 PM
PWalk's Avatar
Where's the Beer?
Actually Kev I used sandpaper for the track, the cinnamon is there for show, and something to run through.
Thx for the idea though
A Pike's Peak course is my next project.
Old 02-17-2003, 08:04 PM
Squishy's Avatar
Quack
anyone have a map or picture of pikes peak? i haven't seen it before.
Old 02-17-2003, 08:43 PM
hmmmm its basically a biiiiig uphill twisty turny course. Like a lots of S's connected vertically..Ill try to find a pic.
-=45mhz Rx7=-
Old 02-17-2003, 08:46 PM
here is a pic, i hope it works
-=45mhz Rx7=-
Old 02-18-2003, 04:54 PM
Squishy's Avatar
Quack
whoa! thats awsome!
Bit Char-G: FAQs (Updated: Jan 6th, '03) Namuna Bit Char-G / MicroSizers 15 08-14-2003 11:04 PM
Would you buy a portable bit track? TeamBonzer Bit Char-G / MicroSizers 10 07-25-2003 08:55 AM
rally racers track isk8blind Bit Char-G / MicroSizers 0 06-18-2003 02:27 PM
Bit Char-G track sucks Zephyranthes Bit Char-G / MicroSizers 8 02-27-2003 05:55 PM
