Old 02-02-2003, 03:08 PM
AZ_Legend's Avatar
AZ_Legend AZ_Legend is offline
Lowering?
Can someone please post something on how they got there zz lowered. I just can't seem to do mine right!
Any help would be helpful.
Thanks
Old 02-02-2003, 07:46 PM
Subie Driver Subie Driver is offline
'00 Subaru Impreza 2.5 RS
http://www.tinyrc.com/forums/showthr...&threadid=6228
I usde the same dremel bit he shows in that pic, and used it to make the new notches in the body of my Civic. I have some pics of it in my Civic Ricemobile thread
27MHz Microsizer White Peugeot 206: 3.8, NiMH
49MHz Microsizer Yellow Lancer Exolution: stock
27MHz LXX Char-G Xanavi Skyline GT-R: 3.0
27MHz ZipZap Yellow F&F Civic: 2.6, Carbon Fiber-look hood, lowered, sport tires, turbo gears
Old 02-03-2003, 10:23 AM
Blamminator
I heated up an Xacto knife & made the notches on my bodies. The Dremel is a better idea, but if you dont have one the hot Xacto works.
Old 02-03-2003, 05:38 PM
AZ_Legend's Avatar
Yeah I saw your civic
sweet ride dude, the real one and the ZZ.
Old 02-03-2003, 05:40 PM
AZ_Legend's Avatar
Just got this civic and I am going to attemt to slam it.
Wish me luck!
Old 02-03-2003, 05:42 PM
AZ_Legend's Avatar
Subie Driver can you post some pics of the inside of your cars body.
thank you
Old 02-04-2003, 03:01 PM
Yeah, I'll try to get some when I get home from work (if I remember). Not much to see, really, I just thinned out the plastic around the wheelwells. Oh, and just doing the notches worked pretty well, but to get the final drop and tuck on the front, I had to remove the suspension bar thingy. But the PCB cover is touching the body as it sits right now, so to go any lower, I'll have to do something about that, but it's low enough for me.
Old 02-04-2003, 04:36 PM
DeuceMan_408's Avatar
DeuceMan_408 DeuceMan_408 is offline
For me I think the xacto blade is the easiest. I have a dremel and the lil square bit but didnt even mess with it. With a new xacto blade the plastic is soft enough to cut a lil at a time. I got the results I wanted with it and it only took a couple of minutes. Not saying that the dremel way will take that long either I just think its easier to slip and take out more plastic than you want with it.
Old 02-04-2003, 06:06 PM
AZ_Legend's Avatar
Yeah, I think that your civic looks awesome and I think that it is low enough
Old 02-07-2003, 09:23 PM
AZ_Legend's Avatar
Just practiced on this PT Cruiser body and I think it turned out pretty well. Sorry you can't see it well but from close my camera really sucks
Old 02-07-2003, 09:27 PM
AZ_Legend's Avatar
doesn't look that low but I had to cut out the wheel wells because the tires were hitting them, causing the car to turn in circles.
Old 02-08-2003, 08:49 AM
AZ_Legend's Avatar
I lowered the front end a little, but i didn't do the back end yet.
I think it turned out alright
Old 02-08-2003, 08:31 PM
AZ_Legend's Avatar
Made the PT Cruiser even lower!
Old 02-08-2003, 08:32 PM
AZ_Legend's Avatar
Sorry for the blurry pic
Old 02-16-2003, 08:19 PM
AZ_Legend's Avatar
Lower Civic
Lowering issue spamman ZipZaps 5 03-26-2004 02:31 PM
Photoshopped SE lowering VuN86 ZipZaps SE 0 09-20-2003 01:25 PM
Lowering Jobs blownPT Bit Char-G Mods and Projects 28 03-27-2003 07:30 PM
bit char-a lowering mrcdemon Bit Char-G / MicroSizers 0 01-05-2003 06:53 PM
Lowering the Civic and Supra latency ZipZaps 3 10-06-2002 03:50 AM
