Old 02-03-2003, 06:32 AM
scottyboyfun's Avatar
Im a cat, miow.
Make UR car go STRAIGHT!
I have a 3 cell extended chassis bit, and it would keep turning to 1 side.
So what I did was spin the rear wheels using the controller, and lightly held the abrasive against each rear wheel, 1 then the other!
The car goes really straight now! AND remember, tricells dont usually do that!!!
SO try it on ur bit n c what u think!
For my abrasive i used a dremmel cutting disc held in my hand NOT USING the dremel, just the disc.
The disc is not the metal one, but the dark red/ brown thin one.
POST UR RESULTS!
So what do u lot think?
Post it!
Old 02-03-2003, 04:30 PM
eman1 eman1 is offline
custom title
Send a message via AIM to eman1
so basically you roughed up the tires so they had more grip. Then 1 tire wouldnt spin more than the other and cause it to veer to one side.
right?
current parts:
auto modellista
4.2 pro
perfection 200mah battery
Pullback wheel mod
Plantraco desktop rover for sale
email me at eman54@optonline.net if you want it
Old 02-03-2003, 04:37 PM
Silent_NightR34's Avatar
Got Mini-z?
wow..my motor just has to much tourqe..way to much...i love them burnouts tho(not donuts)
Old 02-03-2003, 05:08 PM
Im a cat, miow.
Thats exactly it!
It is all easy to forget the basics sometimes.
Traction is why the cars can move!
If it isn't equal on both driving tyres, then it won't go straight!
All I did was rough up the tyres!
BEST way 2 get a good roughness, is to make the motor spin the wheels, then hold the abrasive against the tyre while it spins!
Post it!
Old 02-03-2003, 05:09 PM
Im a cat, miow.
They don't need to be rough rough, just take the shine off the tyres!
U will notice that the tyres will now get loads dirt on them! Thats cos its working!
Post it!
Old 02-03-2003, 06:04 PM
striderpunk striderpunk is offline
Hypnotic ain't she.....
ooookkkkaaaaay?
eman 1 and anyone who say that sounds like a bit has a ball differential a soild axel making it impossible for one wheel to spin more than another. It's not nice to trip up a newbie
see ya on the flip side
Old 02-03-2003, 06:34 PM
Im a cat, miow.
Not sure what ur on about Styder, tripping up a newbie?
But What i was saying, is that it appears that 1 tyre was getting less grip than the other,making it go 2 1 side.
Post it!
Old 02-03-2003, 08:16 PM
custom title
strider-I meant he roughed then up so one tire wouldnt slip more than the other. And yes, my tires can turn seperately from each other. I'm not sure if this happens while I'm driving, but i know they can spin seperately in my hand.
And please use some periods and capitals so i can actually understand your post.
current parts:
auto modellista
4.2 pro
Pullback wheel mod
Old 02-03-2003, 11:12 PM
grilleguard2k grilleguard2k is offline
Send a message via AIM to grilleguard2k
That just sounds like a good way to start hundreds of tiny tears in your tires, ending their lifetime sooner. I recommend using tires as hard as possible in front, and with as little tread as you can get. This way the wheels which would cause the skewed alighnment don't grip and hence don't push you off course.
Would YOU hit it?
Old 02-04-2003, 07:16 AM
Im a cat, miow.
I dont think the tyres will get loads of tiny rips in them, all we are doing is lightly rubbing them down, so they loose their sheen.
If I had a better digi cam then I'd take a close up pic n u would c that no rips will start there.
Post it!
Old 02-04-2003, 07:18 AM
Im a cat, miow.
The tyres are still smooth,not bumpy, all u need to use is a very fine abrasive!
Not a rough one, or the tyres will start ripping as u said!
Post it!
Old 02-05-2003, 10:13 PM
batesjm's Avatar
batesjm batesjm is offline
My Alter Ego Is Retarded
Yo gain a little more traction sand down the wheels to keep the tires flat on the ground. this really helped my 2 cell track strait.
I like Pie
Old 02-06-2003, 08:10 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
striderpunk has the coolest avatar ive ever seen
Old 02-06-2003, 08:14 AM
hogjowlz's Avatar
also extra weight over the rear axle helps. a dime weighs 2.3grams and seems to be about right. look at my 2 battery stability thread. now i burn out on slick floors and go straight.
Old 02-06-2003, 08:31 AM
BenCloned's Avatar
BenCloned BenCloned is offline
Clones Are Good
If your tires spin independently from each other, then when you accelerate, only the tire on the side with the gear is putting the torque to the road, and that will make the car veer to the right. Try pressing the wheels onto the axle harder. All my Tomy axles developed this problem within an hour of running them, but pressing the wheels on harder solved it.
No, the wheels don't bind on the chassis.
Shen Qi Wei:
Begun this clone war has.
- Yoda
How to lose wieght, gain performance, and make your car slide less when turning for0$ rydzjunior XMODS 2 12-27-2006 03:48 AM
i have some cool ideas for zz help me make it work guitarplaya3000 ZipZaps Mods and Projects 4 12-23-2005 04:34 PM
my car wont go straight help me census007 XMODS Mods and Projects 3 12-30-2003 12:35 AM
