Old 02-01-2003, 10:59 PM
Overlander's Avatar
Overlander Overlander is offline
Overworked
Lightbulb How To Build a Micro Tank
This thread will be for tracked or 'skid steer' vehichles and possibly vector thrust boats.
_______________
I just like to build.
Old 02-02-2003, 12:06 AM
Silentbob343 Silentbob343 is offline
Can you use Bit motors? Or do you have to use the GWS motor?
I was thinking about making a tank with two motors, one controlling each tread. What would be involved with this? I was thinking about using two RXs but then I would need a Tx for each RX unless the make TXs that can have controls with two channels at once. Would a six channel RX and six channel Tx solve this problem?
I know this would be too hard for my first 1/87 so I was thinking doing it first on a larger scale and working my way down to 1/87th. I just need to get controlling two motors independently figured out.
I was thinking about it some more:
Instead of connecting a servo to the Rx I just connect another ESC to the second motor. So I would have two ESCs each connected to their respective motors. Will two ESCs and two motors create too much of a power draw for the tiny Rx?
Old 02-02-2003, 12:47 PM
Thorsten Thorsten is offline
Hi,
to power a tank, the bit motors will be to tiny. The easiest way to get an usefull motor (or two) is to dissasemble one (or two of the same) servos.
This will be strong enough to power the tank.
I am use two micro gear motor (50 USD each) from any medicine tools (I dont know it exact) to power the chains of my crane.
The chains was made of a fiend of mine. He made it of brass.
To command this driveline, you need a 2channel remote control (one channel for each chain).
OK, shooting, turnig the pipe, lifting the pipe, lights, smoke, commander comes out of the tank. It should be good to get a 6-channel remote control to power all toys on the tank ;-)))
What is the meaning of "ESCs" ?????
best regards
Thorsten
www.mikromodell.de
Old 02-02-2003, 01:14 PM
Dux Dux is offline
ESCs are electronic speed controls.
I hope this link gets your imagination started http://www.servocity.com/ServoCity/P...rs__chain.html
Old 02-02-2003, 01:16 PM
Overlander's Avatar
Overworked
ESC
Thorsten,
You are either a mad-man or a genious or both!
ESC is a common English term for Electronic Speed Control.
SilentBob,
A 4 channel STICK radio is best for tracked vehicles. You can use the two sticks by pushing them forward and rearward kust like a real tank. This allows you to use the two servo/speed controls proportionally.
More later
-Todd
_______________
Old 02-02-2003, 01:22 PM
Overlander's Avatar
Overworked
Dux,
I have used those .12 pitch chains before! Theey are great.
I used them on the drive line when I converted this toy into a rock crawler!
_______________
Old 02-02-2003, 01:29 PM
Hi,
thank you for declaríng!
In this sice of rc-modeling it is the same thing to use a servo or a speed contoler.
It is better to connect the +voltage and the -voltage of a speedcontoler not to the reciver. The better way is to conecting this directly to the main switch or the battery.
So the amps can't influence the reciver. You need only 1x + and - from the battery to the reciver and each servo/speedcontroler is conected by the signal-wire to the reciver. Nut by the +/- wire.
(I hope you undestand this writing)
If you dissasemble a servo to get the motor, so you can also use the servo contorler as the speed controler.
On the picture you see 6 motors 2 relais 4 speedcontroler 4 batterys and 1 reciver. It works together without any problems (until yet)
@ overlander: nothing of all, just a guy who like to play with small trucks ;-)))))
best regards
Thorsten
Old 02-03-2003, 12:10 AM
I was planning on using a 4 channel Tx, but would I be able to control the turret with a 4 channel Tx?
I purchased my model tank, a Russian T-62, it's only a 1/72 scale though . My local hobby shop didn't have a good selection of HO scale stuff so I made due with what I could find.
I still need to fabricate some moving parts to allow for articulation with the wheel with in the tread, but I need to use a drill press for the precise holes.
The next step is to purchase the electronics but I'm a poor college stundent with little money and little time so the electronics will have to wait for a bit. I need to finish my Bit rally course first before I get to far along in my tank.
What would be involved to run two motors per tread? Is it possible to have two motors wired into one speed controller and keep the motor sets on a channel? Or would each motor need a seperate channel?
Old 02-03-2003, 02:28 AM
killer's Avatar
killer killer is offline
Proud to be Pinoy :)
:ö:Bob,
yes you can control still control the turret with 4channel radio, wherein;
channel 1 : for your right wheel in tank case it's right track (forward & reverse)
channel 2 : for your left track (forward & reverse)
channel 3 : for your turret (left to right)
channel 4 : for you cannon (up and dow)
on channel 1 and 2 you would be needing one speed controller and one motor for each channel, and for channel 3 & 4 you can use 1 micro servo for each channel to move those parts.
just a suggestion
hehehe
Old 02-03-2003, 02:46 AM
killer's Avatar
:ö: now as i understand it, you need two (2) speed controller to run those track (left track and right track), in order to run two motor using one (1) speed controller, i have in mind using a 2 diode in each motor, but i think this will eliminate reverse i'm not sure yet, but i'll test it first if it will work, but i think it would be easier if you'll use two speed controller to run each motor for each track, (channe 1 & 2) push both stick forward and your tank will move forward, release one stick and your tank will move either left or right direction, depending on which side of the tank you want it to turn.- æ
hehehe
Old 02-03-2003, 03:32 AM
Thanks killer
and thanks Thorsten I did understand you writing
Old 03-08-2003, 07:43 PM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
update
any update on the tank project?
Old 03-09-2003, 03:56 AM
Hi arch2b,
I don't know about finishing the tank-project. But my Menck-crane is finished yesterday ;-)
best regards
Thorsten
www.mikromodell.de
Old 03-09-2003, 09:46 AM
arch2b's Avatar
thorsten- that is amazing can you get some video of it working?
Old 03-09-2003, 10:28 AM
Overlander's Avatar
Overworked
WOW!!
Thorsten thats incredible!!
What functions does it have??
_______________
How To Build a Micro Speed Control From a Servo Overlander TTTT 20 05-26-2004 12:21 AM
How to Build a 1/87 Scale RC truck a.k.a.TTTT Overlander TTTT 445 02-25-2004 06:15 PM
Fix for tank with poor performance Alard Combat Digi Q 11 09-12-2003 10:17 AM
Is my tank dead? Halthek Combat Digi Q 3 05-17-2003 03:11 AM
micro x tank help baggy Miscellaneous Discussion 1 03-02-2003 06:22 AM
