Old 07-31-2002, 10:52 PM
SuperSupra SuperSupra is offline
Question Underglow for Bit Char-G
I was wondering, is it possible to put underglow (street glow, etc) on the Bit Char-G's? I don't see any mods or posts about that. It might look pretty cool. Thanks.
Old 07-31-2002, 11:32 PM
tinyrc's Avatar
tinyrc tinyrc is offline
Well, it could easily be accomplished using a standard LED mod but pointing them downwards; another, much cooler way to go would be to use this stuff:
http://beingseen.com
We used this for a Mini-Z and it looked great. It would be harder to adapt to a BC-G, but if you can do it, it would be very cool!
Old 08-01-2002, 02:11 PM
ViperKid's Avatar
ViperKid ViperKid is offline
Redneck Drifter
i bet an LED would be easier, but that's just me. also instead of puting it underneath the car, you could put it on both sides of it.
Old 08-01-2002, 02:16 PM
TheFanMan's Avatar
TheFanMan TheFanMan is offline
Shoot To ILL
Send a message via AIM to TheFanMan
you can get that neon wire really small, but the prob with it is that the battery holder for it is way too big. I'll see if I can find that site I had again, they had it really really cheap and extremely thin wire
Custom:
Toyota Trueno
tires: soft
gear: light blue
shocks: mediums
motor: 2.2
Old 08-01-2002, 04:50 PM
schoon's Avatar
schoon schoon is offline
Send a message via AIM to schoon
Question
The glow-sheet-things appear to be too large fot Bit use from what I can figure from the web-page.
Thus, I'd also think that LEDs might be the better way to go. I'd think that one mounted centrally might do the trick.
Old 08-02-2002, 12:09 AM
TheFanMan's Avatar
Shoot To ILL
omg I thought of an idea and almost wet myself... here goes...
1) www.coolneon.com, they have tiny tiny neon wire that is just small enough to fit under a bc-g
2) get a NiMH battery and put that into your bc-g (I just bought one from QFM )
3) coolneon has instructions on how to solder a lead wire so that you can set your own power source
4) here's the tricky part: connect the NiMH battery to the neon, and then loop, and glue (or however you can attach it so as not to move around while trying to drive) the neon around the front top, and down the sides then right over and b4 the motor plate.
The NiMH has enough power for a gigantic charge, enough to run wire that size for aslong as a normal bc-g will run. AND BAM! neon on your bc-g. I know you guys would rather use LED's but this will look so much better. oh.... and your car may need extra paint so that the light doesn't leak thru
Custom:
Toyota Trueno
tires: soft
gear: light blue
shocks: mediums
motor: 2.2
Old 08-02-2002, 09:06 AM
tinyrc's Avatar
TFM - yes! This is what I was trying to convey. You have to try this, it would be so cool!!!
Old 08-02-2002, 01:54 PM
ViperKid's Avatar
Redneck Drifter
where is Wedginater? we can't have a "light" conversation without him!
Old 08-23-2002, 11:43 PM
Shacky Shacky is offline
Hacked it up
Well I hacked up an underglow, but it doesn't quite work the way I want it too. I think I'll just give up and go with headlights and tail lights. BTW for anyone else trying, I tried to put a battery holder in, but there wasn't enough room. Too bad since the battery holder made it a lot easier to keep pressure on the battery.
Old 08-29-2002, 10:35 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
heh i tried to put tireflys IN my car...damn batteries wouldnt fit...woulda been kool though...
Old 08-30-2002, 12:04 AM
defor defor is offline
Regarding using EL wire, EL wire uses a low-voltage AC power source, thus an inverter of sorts is required. for larger - 1/20 - 1/10 models this is feasable, but on bitchar-g the electronics alone are commonly much larger than the reciever board... you could make your own, but the effect might be much better achieved by using el sheeting (also known as indiglo) from a dead watch and the inverter pulled from the watch. If you're using LED and are experiencing bright pinpointed light, try shining the light up into the body cavity and reflecting it downwards, or roughen the lens on the led with some sandpaper.
-dan
Old 08-30-2002, 12:31 AM
tinyrc's Avatar
Wow defor that's a brilliant idea! Someone try this quick! Oh, and welcome to the Forums defor!
Old 10-17-2002, 11:00 PM
rmyc's Avatar
rmyc rmyc is offline
Perfected Bit Modder
talking bout ELs.....you could get a ~1.25"x1.25 " for about $2
by braking up a soft touch night light/indiglo( from k-mart etc.) and using the EL pad from inside
..only thing is that you have to by a 110vac inverter from an electronic store ..like allelectronics.com
it could be cut to any size/shape and installed under the car
Old 10-18-2002, 09:24 PM
mattattack mattattack is offline
nice
Old 10-19-2002, 06:01 PM
NorCalCoug's Avatar
l33t camber wizard :)
-dan
The Neon wire from coolneon.com is DC powered by a battery. They don't have any inverters anywhere; there's simply a soldered connection, a plastic connector for easy removal/swap, and then it goes straight to a 9volt battery in their applications.
easiest and best underglow ever bengali548 XMODS Parts and Hop-Ups 2 08-05-2006 12:08 AM
panther to bit char parts zakkstyle Bit Char-G / MicroSizers 1 06-25-2003 12:08 PM
UK bit char g life ......... boring Bit Char Bloke Bit Char-G / MicroSizers 10 11-10-2002 08:10 PM
bit char g - bit char g bike -bullet 00gt Bit Char-G / MicroSizers 1 10-26-2002 03:30 PM
