Old 01-09-2003, 02:48 PM
Silent_NightR34's Avatar
Got Mini-z?
well u can also get a 3.0 motor from them...and some 3:43:1 gears..thats wat i did for $2
Old 01-11-2003, 04:51 AM
Spanky's Avatar
Spanky Spanky is offline
Mr. Goop
ii just got three of the kit racers today. had the 4.57:1 gearing. the 2.6 motor and the soft orange tires. anyway i read a couple posts that said to get these gears from the K.I.T to work you have to cut up the frame of the car. that sounded kinda crazy to me because if you do then you would only be able to use the KIT gearing. i just chopped off that spacer thing at the on the wheel opposite of the gear. it fit perfect.
o well there isnt much raw tire spinning acceleration, but it just keeps going faster. i dont have a stretch longenough in my place (6 feet is my biggest stretch.. everything else is thick carpeting or an unrunable surface) to get it up to full speed. i will bring to work on monday to race against the others.
i got mine at target for like 4 bucks. then i stopped at wallmart and they had 2 more but for 7.99. they are the "RPM" model o well im gonna slap the extra cell on this thing tomorow and see if i cant get a little more performance outa this little creature...
Old 01-12-2003, 09:31 PM
JBit's Avatar
JBit JBit is offline
go Go GO, JBit Mifune!
the 2.6 has crazy torque, a great balance of speed and torque, my fave over the 2.2 and the 3.0 right now.
The Mach w/DKS 3.4 Darkside Rotor.
Old 01-15-2003, 01:21 AM
Kaizer-Stryke Kaizer-Stryke is offline
Send a message via AIM to Kaizer-Stryke Send a message via Yahoo to Kaizer-Stryke
hey do u know why my dual cell mod car dont work ? and by wont work i mean the motor wont spin the front wheels move and i hear the motor straining and theres nothing caught in it cuz i took the axle and all the gears off
Don't Knock It Till You Try It. Don't be a hater.
Old 01-15-2003, 01:56 AM
Silentbob343 Silentbob343 is offline
http://home.attbi.com/~silentbob343/Brodie.html
Old 01-15-2003, 02:11 AM
Spanky's Avatar
Mr. Goop
ok. heres my problem. i did the 2.4v battery turbo mod with my clone. unfortnately it only runs slower. could i have missed something??
so i am understangind this correctly the wiring should be something like this
pcb board > +battery1 > -battery2 > +back to pcb.
did i do that right??
please dont say it wont work because its a clone!!! im experimenting on this little chunk.
Old 01-15-2003, 10:47 AM
you shouldn't have had to mess with the PCB just the batteries and metal connectors in the chassis.
Old 01-15-2003, 12:11 PM
Spanky's Avatar
Mr. Goop
but yes you do have to mess with the pcb. if you dont you will not be able to charge the 2.4v that the 2 batteries needs. this is the 2 battery turbo mod. not the mod to make it run longer. the batteries are wired in series not parallel. if they were wired parallel then leaving the controller would be ok, it would just take mulptile charges to get the batteries fully charged.
description of the 2.4v battery mods here
Old 01-15-2003, 12:13 PM
Spanky's Avatar
Mr. Goop
oops. pcb i was thinking controller. i didnt mess with the pcb. that shows that the wire comes from the pcb to the positive of battery one, then from the negative of bat1 to the positive of bat2 and from the neg of bat2 back to the pcb.
Old 01-15-2003, 12:16 PM
lol
yeah, I was like why is he messing with the cars PCB?
You definitely need a multi-cell or ACl charger to get a dual cell up to it's full potential.
Old 01-15-2003, 12:26 PM
Spanky's Avatar
Mr. Goop
cool. i have a 4 cell holder thingy from my bigger rc car. i think it was supposed to be used for the reciever in the car if i didnt have an ESC. anyway it will work great now that i think about it. it still has the plug on it so i think im just going to leaave the charger on the controller, and put a plug on it so i can just plug in the 4cell battery pack. and then put a buncha velcro on the back of it to stick it to the controller..
how long should the charge times be for a 4 cell charger?
Old 01-15-2003, 12:41 PM
hmm...now that's a good question
I typically leave my car on the AC charger for 3 minutes. I have a 800mA voltage adjustable charger: I have it set to 4.5volts.
Old 01-15-2003, 12:50 PM
Spanky's Avatar
Mr. Goop
are there any electrical geniuses out there that could possibly post some type of time scale for charging moded cars. for example a 2 cell car on 3 batteries, on 4 batteries, on a car battery... lol that kinda thing.
Old 01-15-2003, 04:33 PM
Spanky's Avatar
Mr. Goop
ok, time to put to gether the 4cell charger... am i supposed to just wire this directly to the charger? or do i need some other electronics along with it? using 4 cells sounds like it might do some damage to the batteries in thecar.. is it to much voltage to charge with? ive only got 2 cells in my car.
i dont understand why the two AA's wont give it a full charge... im not gonna run any risk in frying anything with 4 AA batteries am i? 4 AAs would be 6v.
Increase short battery life! underglow ZipZaps SE 1 09-17-2005 06:51 PM
