01-09-2003, 09:30 PM
My R32
Another angle....
My R32
Front.
01-09-2003, 09:31 PM
My R32
01-09-2003, 09:46 PM
Corolla Power!
Re: Here...
Originally posted by TemjinNeo78
Here is my dual cell Xanavi Beast....
Specs:
Mach 5 chasis
Zip Zap 1.6...scared to put anything bigger....
clone zip gear combination(occasionally bit racer gear)
150 MaH DKS Little Green men nimh cells...
WOW! That is the baddest LXX I've ever seen!!!
DriveWRX - Beautiful as always...how'd you make/get the rims?
01-09-2003, 10:04 PM
hey DriveWRX how did you lower it that much??? And where did you get those rims?? lol that looks so cool!!
01-09-2003, 10:19 PM
SPEED IS GOOD
NICE SKYLINE!!! The DUBS RIMS looks nice!!!!! How did you put the fronts on????
01-09-2003, 10:52 PM
My R32 Rims
Thanks guys!!!
Yep, those are DUB rims, 1/64 scale! (Credit goes to maricopa97_02 on Admiral's Lair)
It took a lot of tweaking to get the rims on. Especially the rears, lots of shaving/grinding needed.
Fronts were a lot easier. Drill a hole thru the center of the DUBs, pop the pins from the knuckles, put DUBs on and replace.
The smaller diameter of the DUBs helps tremendously to lower the car. The body still needs to be modded to get it LOW!
The tires are just plastic unfortunately...
Not much grip on smooth surfaces. AWESOME for doing donunts though!
Took some work, but I'd do it again...
JADA Toys (maker of DUBs) said they are putting out more rim designs! Can't wait!!!
One more pic...
01-09-2003, 11:25 PM
SPEED IS GOOD
Hmm my uncle has a spare set of DUBS from his little astro van thing from JADA. I need to see if i can get those!!! I wonder if Bit tires can fit on those wheels.........
01-10-2003, 02:52 AM
Regulator
01-10-2003, 06:15 PM
Unfortunately, no!
The DUB tires aren't bad. They compare to Tomy hard tires.
They have a little tread which helps traction a "bit" (  ).
Thanks Shypo!
01-13-2003, 01:26 AM
SPEED IS GOOD
Hmmm well i got the DUB wheels niw, But i can't figure out how to mount the rear wheel to the axle. The Wheel on the gear side seems easy to mount, but the wheel on the other side is to short! How'd you mount it DriveWRX?????
01-13-2003, 02:44 AM
Regulator
Drive:
i want that done, if i can get a R32 shell can i send you a chassis and a R32 and some money and you do that for me. please
01-13-2003, 07:57 PM
6v battery=NOS!!
I have the cheesiest skyline on the planet. but put it this way... this is my first mod and im 12
01-13-2003, 07:59 PM
cool....ricey.... lol!
01-13-2003, 08:16 PM
Got Avatar?
My skyline is just stock from the Modestilla set right now. Nothing to exciting, i have a whole wack of mods planned for it,.
One day wanna incorporate these wheels to it... along with a dual motor mod for torque
***  AmC Certified  ***
