Old 01-05-2003, 09:12 PM
New_B New_B is offline
Wowzers...
Send a message via AIM to New_B
Wierd Steering
Hey, I have a problem, and I was wondering if any of you could help me. You see, when I was adjusting the steering magnet, somehow I messed up the "centering spring". It's bent awkwardly and seems to be defective. When I put it all back together, I tested the steering. When I turn left, the car turn right, but when I turn right, it does nothing. I've tried to figure out the problem for hours, but my solutions are hopeless. Will I have to find/buy a new "centering spring"? Is it fixable? Please help immediately. I'm dying of boredom .
Nothing here...
Old 01-06-2003, 03:58 AM
Sid Sid is offline
woah
man seems u really damaged the car....im not really such a technical guy maybe someone else can help u...can u post pics of the magnet area if possible?
45 MHz Nissan Gloria Bit Char-g
Custom Tires (back)
Medium tires (front)
TOMY Bit Racer 2.6 Motor
Old 01-06-2003, 07:40 AM
jah_jrok jah_jrok is offline
I drank what?? (Socrates)
First off, it sounds like your magnet is backwards. As far as the steering spring, well you could try to tweak it back to close to the way it was. I wrecked my first clone in an attempt to make it steer 'Better'.........
Old 01-06-2003, 11:13 AM
Stridex's Avatar
Stridex Stridex is offline
Chunk
Quick alternative you may want to try. I used a slide rail and some thin foam to align my car and it works a lot better then the centering spring you messed up. Looks like crap, but it gets the job done.
A religious war is like
children fighting over
who has the strongest
imaginary friend.
Old 01-06-2003, 11:48 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
thats interesting. can you go into detail on how you do that?
Old 01-06-2003, 12:20 PM
tory_103 tory_103 is offline
Sangru Lava U Sangru
Send a message via AIM to tory_103 Send a message via Yahoo to tory_103
sounds like your steering magnet is in backwards....... and also one of your thin hair steering wires is broken, thats why when you turn the other way you get no response at all, trust me man, been there, done that, 5 times ! you just need to resolder the wire(s) back.
if it dont work, then at least you have a new Parts Car! haha......l8r
Old 01-06-2003, 01:35 PM
Wowzers...
I have tried to fix the "centering spring", but it's no use. It bends every which way. I'll have pics posted up soon. Thanks for the foam idea Stridex. Might try that.
Nothing here...
Old 01-06-2003, 02:16 PM
m0nkeyCharG's Avatar
m0nkeyCharG m0nkeyCharG is offline
TinyRC Padawan
I bent one side of my steering spring when i was doing the REM mod
I mananged to somewhat straigten it, but now, my wheels only straigten when the vehicle moves.
*on topic* I have to agree w/ the other posters, i think u pulled one of the steering wires.
*off topic again*: has anyone done the dual steering spring mod? I saw it on a post in this forum; and i was just curious if it reduced steering ability.
Bit Char-G Garage
Subaru Impreza WRX [Blue and Black]; Project D; Nissan Skyline GT-R set; Mazda RX-7 FD [blue]; Mitsubishi Lancer Evolution VII [Yellow and Rally Color]; Toyota Supra [Silver and Castrol race Color]; Auto-Modellista set
Old 01-06-2003, 02:47 PM
Wowzers...
Okay, here's the pic.
Nothing here...
Old 01-06-2003, 02:50 PM
Wowzers...
Another Pic...
Nothing here...
Old 01-06-2003, 03:36 PM
TinyRC Padawan
ur spring should be fine...It should still be able to return ur magnet to the center of the steering box.
Bit Char-G Garage
Old 01-06-2003, 03:42 PM
Wowzers...
Okay, now I put it back together, and it has caused grey hairs to grow on my head. It won't even turn now. Any suggestions?
Nothing here...
Old 01-08-2003, 06:16 PM
Wowzers...
Question, will a Zip Zap steering spring fit in a Bit Char-G? Another question, will a Bit-Char-G body fit the Zip Zap chassis?
Nothing here...
Ideas on how to increase steering power mde Bit Char-G / MicroSizers 4 05-01-2004 02:42 PM
Steering issue cdog4w Bit Char-G / MicroSizers 21 12-30-2002 10:20 AM
Sharper steering solved Mr Freeze Bit Char-G / MicroSizers 9 12-10-2002 08:01 PM
