01-06-2003, 12:44 AM
Rice Me
Does multiple charges actually WORK?
with a stock battery and stock charger, how many charges actually help?
01-06-2003, 12:52 AM
MASTER PAINTER
i did 3 charges in a row once, let the body side upside down. let it run, it went for about 45 minutes!!!!
it does work, speed doesnt cange much
01-06-2003, 12:56 AM
Rice Me
01-06-2003, 01:59 AM
PLOOP!
does this work with stock batteries? or just the upgraded ones?
01-06-2003, 02:03 AM
From Everything i have read stock batteries respond in like manner. The only difference is the smaller the battery capacity , the lower the run time. So while you may have INCREASED run time on your stock 50 mah w/ multiple charges it still wont outlast the higher capacity battery w/ multiple charges. Hope that helps.
Dual/Triple Cells Available
66 Pontiac GTO, Chevy S10, 69 Doge Charger, Hummer, Escalade, Acura Rsx Type S
01-06-2003, 04:49 AM
does it work....
does this work on Panther clones?
45 MHz Nissan Gloria Bit Char-g
Custom Tires (back)
Medium tires (front)
TOMY Bit Racer 2.6 Motor
01-06-2003, 06:15 AM
MASTER PAINTER
it should work on ANY clone
01-06-2003, 09:32 AM
ive found that it will work for any clone or bit as long as it is not a honda model. for some reason hondas do not double charge.
i think the reason that hondas dont work is because i was lying and it works for all rechargeable batteries. the worst thing that will happen is it will overheat so if the battery ever feels warm you have filled it and any more juice is going to damage your 3$ battery.
01-06-2003, 04:15 PM
PLOOP!
you guys know how many charges it would take to fill a dual nicad clone?
01-06-2003, 04:18 PM
a whole bunch
01-07-2003, 02:25 AM
hogjowlz i tried chanrging my Panther clone 2 times and didnt find a real difference and I dont think i will try it again, already broke one car and dont wanna lose this 1 too...may blow up or somethin
Custom Tires (back)
