01-03-2003, 11:18 AM
Wild Char-g owners becareful
not sure what i did, but it seems the rear wheels(rubber ones) aren't grabbing the hubs, so the Wild G's not moving. The gears are good, and everything is turning as they should, but the wheels are not gripping. Almost like the inside of the wheels expanded or something. This happen to anyone else? Time for another check-up
______________________________
Automodelista: 3.8, 150mah, spring sus.
Wild-G: Raise Tiger w/3.8@the wheels & 2.2@the plow, 150mah
Lancer EVO: 3.0, 150mah, drift set
Hummer shell: 3.8, 150mah, spring sus.
01-03-2003, 11:23 AM
01-03-2003, 12:08 PM
Sith Bit Racer
They snap on and off, so make sure they are snapped on fully.
01-03-2003, 01:47 PM
01-24-2003, 04:49 PM
FIXED!
i pushed 2 of the 4 holding tabs in the wheel downward a little, to the point where it looked like they were about to break. Then i applied super glue at the base of the 2 tabs to secure them to the wheel. Let it dry, then...snap! they grab on tight as new!
worse comes to worse, if the tabs break off - Then i would have glued the wheels to the hub.
