Old 08-12-2002, 10:25 PM
_NiTrOuS_'s Avatar
_NiTrOuS_ _NiTrOuS_ is offline
LoWeReD
hown to you lower the chhassis of the Bit?
Old 08-13-2002, 04:16 AM
btlmr's Avatar
btlmr btlmr is offline
TinyRC Chief
Send a message via AIM to btlmr
Remove the stabiliser bar. I didn't lower the chassis on mine, I lowered the body on the chassis.
butler
_______________________
Size clearly isn't everything...
Old 08-15-2002, 11:18 AM
striderpunk striderpunk is offline
Hypnotic ain't she.....
the stabilizer bar broke off my car already
Old 08-16-2002, 03:48 PM
cowfish_29's Avatar
yellow fish forever!
then its probably...lower?
Old 08-16-2002, 03:54 PM
Wedginator Wedginator is offline
I luv LEDs
Don't take the stabilizer to lower your car. You'll get horrible handling.... The way to get a "lowered" look of the car is to put another set of rear wheels to replace the front wheels.
Another way is to lower the car is to lower the entire body.... Up to you on how to do that....
Old 08-16-2002, 05:02 PM
_NiTrOuS_'s Avatar
oh, ok i think ill lower the body because i dont have another rear wheel
Old 08-16-2002, 05:28 PM
Neon_Skylineboy's Avatar
Neon_Skylineboy Neon_Skylineboy is offline
Send a message via AIM to Neon_Skylineboy Send a message via Yahoo to Neon_Skylineboy
how do u lower the body?
Old 08-16-2002, 05:39 PM
was ist los?'s Avatar
was ist los? was ist los? is offline
SpeedFreak
you could make a body kit and make the car appear lower with epoxy putty. usually this is available at your lhs.
Old 08-16-2002, 09:35 PM
I luv LEDs
One way of lowering it is to use a dremel and grind the slots where the chassis tabs go in.... grind them till you get the right height.... the rear is easy, but the front is a bit more tricky... then fill the unwanted gap with putty.....
Old 08-16-2002, 11:52 PM
TheFanMan's Avatar
TheFanMan TheFanMan is offline
Shoot To ILL
Send a message via AIM to TheFanMan
you might want to buy one those stabalizer kits since your done went and broke off.... or buy some springs when QFM comes back
Custom:
Toyota Trueno
tires: soft
gear: light blue
shocks: mediums
motor: 2.2
Old 08-17-2002, 02:42 AM
QFM Racing's Avatar
QFM Racing QFM Racing is offline
Moderator - Modifier
See the lowering mod at the QuestForMadness.com website. Click into the mod on the left hand side.
QFM Racing's Custom Bit Modifieds (The Bit How-To Page)
http://questformadness.com
Old 08-17-2002, 01:47 PM
_NiTrOuS_'s Avatar
k, ill do that, thanks.
Old 08-29-2002, 10:56 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
does a lowerd ride improve performance any?...probably not THAT realistic to real life physics.....
Old 08-30-2002, 09:53 AM
I luv LEDs
Nope, I don't think so. It just looks better.
Old 08-30-2002, 11:49 PM
Redfire's Avatar
Redfire Redfire is offline
Just kinda burned you...
Send a message via AIM to Redfire Send a message via Yahoo to Redfire
sooooo, lowering your bit is a bad thing for performance, yet it makes your but look cooler. am i correct?
"I won't lose, no matter what, because the prize is a full tank of gas." Takumi
Finally lowered my rx7!!! AE86 Toyota Bit Char-G / MicroSizers 4 03-28-2006 02:54 PM
Lowered L-ion GT40 LBRC Mini-Z - Mini-ZRacer.com 3 12-23-2004 11:57 PM
lowered truck pictures biohazard Bit Char-G / MicroSizers 48 05-21-2003 11:50 AM
Lowered bit? Trouble with wheel rub on fenderwells? NorCalCoug Bit Char-G Mods and Projects 1 10-17-2002 12:13 PM
test post... lowered Honda? tuner00 ZipZaps 11 10-08-2002 03:27 PM
