Go Back   TinyRC.com > 1/64 and Smaller > Digi Q > Digi Q
Old 12-23-2002, 06:43 PM
wooglin wooglin is offline
Wont Charge
I just got a digiQ fairlady Z, and it only charged twice. Now when I place it on the controler to charge, no charge light appears. I have tried new batteries, etc. Any Ideas?
Thanks,
Alan
Old 12-23-2002, 11:06 PM
gertman's Avatar
gertman gertman is offline
Sorry to hear your having problems. Here are some suggestions:
Make sure the car is off and the controller is on. Try taking the car in and out of the charging bay. The contacts on the bottom of the car may not be making good contact with the contacts on the controller.
Hope I've helped
-Engineering Manager
Old 12-23-2002, 11:11 PM
Figured it out... THanks
It is weird... If I just leave the car in the charger after about 2 minutes the charge light comes on. This is only if the car is totally dead. Happens if I leave the switch in the on posisition on the car. Anyway thanks for your advice gertman. I have some new goodies on the way.
Epoch Indoor Racer Spec 2 WRX
Propo Special Digital Controler
Old 12-23-2002, 11:15 PM
gertman's Avatar
Now...
when you get the Propo Special Controller your problem should be fixed. If NOT than, there is something up with your car.
Old 12-27-2002, 03:32 PM
Dougboy's Avatar
Dougboy Dougboy is offline
climate control
try cyceling the battery in the car.
Drink Your Milk
Old 01-04-2003, 12:04 PM
loztboy loztboy is offline
well i am having the same problem right now. I have the pitwork skyline and the nsx-r and the ae86 trueno. Well for some strange reason the syline and the nsx-r are not charging at all i do not know what the hell is going on because i just got these. The trueno is fine i am suspecting its something to do with the fact they have lights. I tried charging with the car on but all that happens is the lights just flash, and when i turn it off and dock it the charge light will not go on. Any help would be appreciated i've only had these digiq-r's for 2 days!!!
Old 01-11-2003, 08:44 PM
Try placing the car turned on of the handset, and leaving it for 10 minutes regardless of whether the light is on or not. Just try it, you may be suprised to find the light comes on after a few mintues.
Old 01-12-2003, 03:45 PM
mattdaxlr8er mattdaxlr8er is offline
does the green light mean charge and the red is full?
bubble car.
Old 01-12-2003, 04:32 PM
lachendr0 lachendr0 is offline
Doug you say tryi cycling the batteries. how do you go about do that?
Give a man a fire and he'll be warm for a day. Set a man a fire and he'll be warm for life.
charge rate?????????? fisherman2000 ZipZaps Monster Truck 1 03-14-2006 10:27 PM
FYI:Motor Works (clone) charging base will charge dual and triple battery setups. Clint Bit Char-G / MicroSizers 0 02-17-2003 04:09 PM
My LXX won't charge Nenox Bit Char-G / MicroSizers 3 11-30-2002 06:16 PM
charge time sipsap ZipZaps 5 11-25-2002 11:32 PM
