Go Back   TinyRC.com > Miscellaneous Discussion
Old 12-14-2002, 05:42 PM
GiantScale GiantScale is offline
Send a message via AIM to GiantScale
NIMH vs NICAD & 4 cell battery holder charging?
Iv got a few nice adjustable chargers (graupner Duo plus II & C&E pitt-bull ) and I just bought a few AA 4 cell holders with which Id like to use to charge 4 AA NIMH or NICAD batteries with.
What charge rate should I use for 4 & cut-off voltage?
I also considered the ni-cads also since they have better punch and handle the abuse of mulitipal charge cycles a day.
Anyt comments welcome..
Mike
stranded in iowa
Old 12-18-2002, 07:02 AM
Anyone?
OK, lets make this more simple..
What kind (brand & mah) of AA's are the best for a Mini-z which would get recharged many times a day, and how many amps should I peak charge all 4 batteries together at?
Thanks
Mike
stranded in iowa
Old 12-18-2002, 08:05 AM
Namuna's Avatar
Namuna Namuna is offline
Make sure the batt holder is setup in series and that you put the batteries in, in series.
NiMH & NiCads are 1.2v, then 4x1.2v = 4.8v
So, set your charger up for 4.8v
For Fast Charge:
Set the amperage = to the rating of the batteries (ie; if the batts are 1700mAH, set the amp charge rate the same)...1 hour later you've got charged batts
Notes:
- Since the batts are loose, they're not 'matched' to each other, so depending on the 'monitoring' capabilities of the charger, you're likely to get uneven charging
- MONITOR THE HEAT!!! coming off the batteries while you're charging them...If they get excessively hot, use a lower amperage rate to charge them.
Old 12-18-2002, 11:19 AM
Thanks Namuna!!
So I should charge 1700 mah batteries at 1.7 amps, to charge them in one hour?
What AA's are the best? Who makes them?
Thanks again!
Mike
stranded in iowa
Old 12-18-2002, 12:32 PM
Namuna's Avatar
IMO, Maha (aka PowerEX) is the current champ for AAs. You can get them in 1800mAH capacity.
Yes, if you charge at the rate of the batteries capacity it'll take 1-hour to charge
Old 12-19-2002, 12:09 PM
Thanks again!
I just ordered the MaHa 1800's 12 bucks a 4 pack.
Mike
stranded in iowa
Holder for battery SmokeysDad Bit Char-G / MicroSizers 5 07-04-2003 09:23 PM
Can somebody tell me an easy duell cell mod please? RobotGT Bit Char-G / MicroSizers 16 05-10-2003 08:14 AM
2 nimh Cell charging xsboost94 Bit Char-G / MicroSizers 1 09-17-2002 12:49 PM
