Go Back   TinyRC.com > 1/24 and Smaller > Dynamite Rocket Racer > Dynamite Rocket Racer
Old 12-12-2002, 12:11 PM
Scar Scar is offline
IRC, Siress- Need bigger front rims
Hey My RR is just much for the front tires to get grip and makes WAY to big of turns. THe front tires with Foam tires are just sliding along LOL
Where can I get Bigger rims for both the front and BACK that will handle more foam??
Old 12-12-2002, 05:46 PM
irc irc is offline
IM not sure about wider rims? Try to putting a little WD40 on a rag and wiping it on the front tires and towel the excess off. Let me know how much steering you have after you have tried this.
" THINK FAST "
Old 12-12-2002, 06:00 PM
Hey IRC,
Ill try that but I dont want to have to do that every time I want to drive it??
Or is that like a once every 4 runs type thing?
Old 12-12-2002, 08:21 PM
Siress Siress is offline
Send a message via AIM to Siress
lol, IRC!
You don't need more tire. there is a little thing on the radio about where your middle finger rests while griping the radio. it has a dial, kinda like a volume dial. This is your stearing adjuster. The more you want turn it up, the less, down. As for grip, what surface are you running on? For the most part and for most surfaces, use Zip-Free Foam Tire Traction. It makes the foam sticky. To apply it just gently touch the tire with the sponge head and remove, turn the tire and do it again, doing this to every tire until their coverd completely. BECAREFUL!!! this stuff will MELT your lexan body! eheh read the warning lable on it! lol, scary! If useing that stuff doesn't improve the grip for you, try softening the front suspention. To do this just cut 1/4 loop off of each spring on the front. Do this until your getting traction.
Old 12-12-2002, 10:13 PM
irc irc is offline
Good tips Siress, But the WD40 trick works well also. Most cars oversteer so you have a very uncommon problem. Like Siress says make sure your steering is turned up all the way. Also try to tighten your diff up some
" THINK FAST "
Old 12-12-2002, 10:15 PM
IRC, something I like about you is that your very knoldgable and very happy" "
Old 12-12-2002, 10:17 PM
and hurry up and answer my thread in DRR
Old 12-12-2002, 10:57 PM
Cmon guys give me credit I tried the steering to up down the foam is just slipping on my tile..
Concrete it works great though. Even my SLICK concrete
Iam going to try the wd40 to see how it goes.
Old 12-12-2002, 11:05 PM
irc irc is offline
Sorry Scar I assumed in my original post you had the steering turned up but just wanted to make sure. The WD40 may slide for a lap but then hook up. How did you mount the front tires? Tape or glue? What shore/ compound are the front and rears?
" THINK FAST "
Old 12-12-2002, 11:30 PM
Hey IRC,
I glued them and there shore 40..
I just dont have the weight up front or its just pushing to hard.
Ill give you aupdate soon on the wd40 trick thanks bro!
Old 12-12-2002, 11:34 PM
irc irc is offline
Cool, if that wont do it try some 30 shores up front.
" THINK FAST "
Old 12-14-2002, 10:48 PM
oh... haha, the biggest reason of them all that just sliped my mind, lossen up the front suspention! take a spring out of a cheap pen and cut a fairly large piece and keep cutting about 1/4 turn until it doesn't spin out easily. Just mess around with it until you like it. For right turn oval tracks I put a softer spring on the right side of the fornt so that if it tilts in the corner (and it sometimes roles its so fast) it keeps better traction on the track.
Mounting Mini-Z bodies on Xmods neurokinetik XMODS Mods and Projects 18 12-28-2005 05:13 PM
TRC Alloys Instructions HammerZ Bit Char-G Parts and Hop-Ups 6 12-12-2004 09:15 AM
How do i take the front rims off matt333 Bit Char-G / MicroSizers 13 11-13-2002 01:33 AM
