Old 12-11-2002, 05:29 PM
ZippyZappers ZippyZappers is offline
Send a message via AIM to ZippyZappers
MHZ Modification?
Is There Any Way To Change the Mhz To diff one? For Example a 27 Mhz can i change it to a 49Mhz Some how?:confused
ZZ Orange Supra, Antenna mod
Old 12-12-2002, 03:45 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
I don't think so. At least, it would be extreamly difficult.
Old 12-12-2002, 03:47 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
im pretty sure theres a crystal buried in the electronics that would have to be swapped out.
Old 12-12-2002, 05:38 PM
cisco cisco is offline
It is probably too much trouble for what it is worth.
Old 12-12-2002, 06:06 PM
Azimov's Avatar
Yeah, that's the problem. You would need to change the crystals in both the controller and the car. That's assuming that they are compatible. Then, there may be associated components surrounding the crystal that would need to be altered to match the new setup. And, lastly, this all assumes that you can work with SMT components with a very deft hand and excellent soldering abilities. Just a small amount of solder completely changes the resistance of a circuit and all your work is undone. Not really worth the hastle when 20-30 bucks would buy a new car in the frequency you're looking for.
Old 02-18-2003, 11:50 AM
scottyboyfun's Avatar
Im a cat, miow.
The SMT isnt 2 hard to work with, I am confident in doing it.
There is no crystal in the car, just components which together give the car its frequency.
So what do u lot think?
Post it!
Old 02-21-2003, 09:09 PM
Demon666's Avatar
Demon666 Demon666 is offline
V-tec aholic
i saw this mod done on the forum before ill try to find it. the guy mad a switch with both crystles.
Drive it like ya stole it!!
49mhz/SKYLINE/2.6/STERING SPRING MOD/ANTENA MOD
27MHZ/SKYLINE/2.6/DUEL CELL MOD/ANTENA MOD/STERING SPRING MOD/WHEELY BAR MOD/CARBON FIBER HOOD LOOK.
Old 02-22-2003, 05:29 AM
Im a cat, miow.
So far I have found out that you will have to change the tuning coil, a capacitor (i think its the one closest to it), I'm not sure which other components.
In theory it should be possible to make the car respond to all frequencies, so then we could tinker it, and find a way to make it filter out the unwanted frequencies.
Post it!
27 mhz vrs. 49 mhz or is it Regular vrs SE Sleeping911 ZipZaps SE 4 08-13-2004 09:14 PM
What's the best Mhz to run with... bloodyroots Bit Char-G / MicroSizers 8 05-05-2003 12:59 PM
02 MHz and other odd MHz noxorc Bit Char-G / MicroSizers 3 02-23-2003 05:49 AM
35mhz crystal worked on 27 mhz transmitter ejaf ZipZaps 3 12-11-2002 08:30 AM
range of 27 MHz versus 49 MHz gRC ZipZaps 12 09-30-2002 06:33 PM
