Old 12-05-2002, 12:04 AM
plexxx plexxx is offline
my cars antenna broke
the antenna broke, i had extended it by untieing it from under the pcb for increased range. It snapped off at the base. I think i need to desolder the little bit and then solder in a piece of cat5 cable (this is a mod i wanted to do anyway, now its just a little harder). Has anyone else had to do this?
Old 12-05-2002, 09:44 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Retarded Stunt Driver
ya just solder it back on. better yet use brand new wire. cat5 if you want.
they tied that knot for a reason.
Old 12-08-2002, 12:05 AM
I soldered a piece of CAT5 to the antenna node and it worked great for 2 charges then the steering stopped working right. It can turn right but not left. The steering wires look OK.
Old 12-08-2002, 12:24 AM
Stridex's Avatar
Stridex Stridex is offline
Chunk
Make sure the front wheels are free of hair and lint. That's always my problem with my hardwood floors. If that's not it, make sure you haven't picked up anything magnetic that may be stuck and hidden to the bottom of the chassis. Can you turn in both directions when you have the car off the floor?
A religious war is like
children fighting over
who has the strongest
imaginary friend.
Old 12-08-2002, 07:47 PM
You were right, I found a small piece of metal above the alignment tool under the car. Scraped it off with a knife and now it works.
need a new TX antenna? TypeZer0 XMODS Parts and Hop-Ups 3 02-15-2004 08:09 AM
Alternate antenna ideas! caver01 Bit Science 214 11-07-2003 10:38 PM
Antenna Support System got BITS? Bit Char-G / MicroSizers 7 03-27-2003 12:25 PM
My antenna broke Zephyranthes Bit Char-G / MicroSizers 2 03-07-2003 12:34 AM
antenna broke!!!!! microsizer ZipZaps 19 11-15-2002 11:26 PM
