Old 12-04-2002, 12:09 PM
8ate8 8ate8 is offline
Send a message via AIM to 8ate8
steering correction switch
what exactly does the switch underneath do? i know it helps correct the streering, but i've taken apart the front end and the piece it moves is just plastic and it doesn't attach to anything. so what i'm asking is how does it help correct the steering? in a nut shell, how does it work? i'm new and trying to learn
Old 12-04-2002, 12:43 PM
Zakkorn's Avatar
Zakkorn Zakkorn is offline
Life's a... Bits
Send a message via ICQ to Zakkorn
If you noticed, near at the top of that plastic is a very small bump.
That pushes a little the steering thing.
So if you put it at left, your car will intead of straight will go left.
And the opposite if you put it to the right.
  • Nissan Gloria 2.6 + LightMod + 120mAH Cell -- Honda S2000 Silver 3.0 -- Nissan Fairlady Z 3.0 -- Toyota Supra Silver 3.0 -- Mach 5 3.8 -- Ultra Patrol 3.0 -- Ultra Cosmo 2.2 -- Auto Modellista 2.2 -- Bir Racer TRAX Green 2.6 -- DigiQ Subaru Impreza -- Ferrari Set -- LXX -- AudiTT SE ZipZaps -- Mazda RX-8 XMen ZipZaps
Old 12-05-2002, 05:21 PM
GoOsEmAn's Avatar
GoOsEmAn GoOsEmAn is offline
BiT TuNeR
Send a message via AIM to GoOsEmAn
ive put that ting to all sides and it still goes the same way...
*GoOsEmAn*
Old 12-05-2002, 07:37 PM
Zakkorn's Avatar
Life's a... Bits
What do you mean it goes the same way?
It should change direction, even slightly.
Disassemble the front of the bit and check if everything is in place.
If you don't know how to open it go there
http://www.ausmicro.com/technical/bi...w-to/index.htm
The DIP Switch Mod ph2t Bit Science 8 08-19-2003 09:05 PM
Steering issue cdog4w Bit Char-G / MicroSizers 21 12-30-2002 10:20 AM
